Oil In Coolant resevoir???? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 07-17-2006, 02:11 PM Thread Starter
FNG_Eric
ericausand's Avatar
Hi Everyone,
I have had a chocolate milk color liquid rising to the top of my coolant resevoir lately and I am wondering if it is oil. I just bought the bike six weeks ago from a dealership. I brought it back to him and he told me he flushed the cooling system and changed the oil, I'm not sure if I believe him. He also told me the bike runs perfectly which it does.
So I guess my question is this, is there a way for the coolant to be taking in oil from the engine?
Thanx!
Eric
ericausand is offline
post #2 of 14 (permalink) Old 07-17-2006, 02:45 PM
HAWK
Ccspinner's Avatar
Yes, if a head gasket is bad would be the main reason. or if someone put oil in the coolent resivore, I have herd of people doing that thinkiong it is a oil tank.
How does the oil in the motor look, is any coolent geting in there? If so you may have a crack somewhere.
The best case is if the old coolent was verry dirty and the dirt is flotong to the top.
Have you opened the coolent system and looked what is in the radiator?
Also what year and miles is the bike?
Hope this helps
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 14 (permalink) Old 07-17-2006, 04:04 PM
Rubline's Avatar
Take it back to the dealer and insist that coolant doesnt look the way it does. If you have extra cash take a sample of the coolant and take it to a lab and have it tested for motor oil. Its not an expensive test,, maybe 20 bucks. then take the results back to the dealer and tell them you want your money back. They sold you a defective product. Im sure they wont give you a hard time if you have lab results that state you have motor oil in your coolant. Are you loosing oil? and is your coolant level rising?
Rubline is offline
post #4 of 14 (permalink) Old 07-18-2006, 03:34 PM Thread Starter
FNG_Eric
ericausand's Avatar
The oil is leaking very slowly and there is a drip underneath the bike.
post #5 of 14 (permalink) Old 07-20-2006, 08:42 PM Thread Starter
FNG_Eric
ericausand's Avatar
The dealer has agreed to replace the headgasket after all!!
I was worried I would have to return the bike for a refund.
I have grown quite fond of the bike and I plan on doing quite a few upgrades ie. cruzers, windshield and whatever bolt on chrome I can find.
post #6 of 14 (permalink) Old 07-21-2006, 04:45 AM
And a dealership surprises us again !!!
Glad to hear they're fixing it for ya. Be sure to ask if ya get any warrantee for the work they do. (in miles, not days)
post #7 of 14 (permalink) Old 07-21-2006, 12:09 PM Thread Starter
FNG_Eric
ericausand's Avatar
will do, thanks!
Eric
post #8 of 14 (permalink) Old 07-27-2006, 10:19 AM
Sky Rider's Avatar
Is this a new bike or an older one? One other point of failure for mixing coolant and oil is the mechanical seal that separates the oil pump from the water pump. Both are on the same shaft. The water pump impeller is external and the oil pump is internal. If the mechanical seal is leaking, oil can get into the cooling system and vice versa.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 14 (permalink) Old 07-27-2006, 12:17 PM
Once Banned
cegodsey's Avatar
That's good to know. Thanks, Jim.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #10 of 14 (permalink) Old 07-27-2006, 02:16 PM
Hey! Just drain the water and put new 50/50 antifreeze (prestone at O'reillys)in. If you see oil in it afterwards then look for problems. Be careful about flushing, some of that flush stuff is harmfull to aluminum.Good luck!
bilyum is offline
