Cylinder honing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 09-23-2011, 06:58 PM Thread Starter
ruk
Cylinder honing
I have a question for the experts, I recently dismantled a 2001 engine with about 10K miles. I studied Roach's youtube videos ( thank you) and I got everything just right. My question is, does the cylinder walls need to be honed if I am reusing the same rings and piston? All rings and pistons are still good per OEM spec. Thanks
Ruk,
2001 VN750-Black/Silver
9900 Miles
Stock Everything
=Rotella-T 10W-40, SuperTech 6607=
ruk is offline
post #2 of 3 (permalink) Old 09-23-2011, 11:56 PM
Chucklehead
dragon159's Avatar
From my experience, I always looked at replacing the rings as cheap insurance once down that far. As for honing, you don't have to go crazy. but I would run a hone through the jugs just to break up any glazing. Then wipe a good coat of oil on the walls for assembly. The inexpensive hones that fit on a drill work just fine for that, just work it in and out to get a decent cross-hatch.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #3 of 3 (permalink) Old 09-24-2011, 12:25 AM
If only it had 6th gear..
DavesVulster's Avatar
X2 on the cheap insurance . You're in there, might as well do them...
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
