exhaust pipe diameter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-17-2011, 08:18 AM Thread Starter
i am wanting to degoat and remove the mufflers and run straight pipes to the back this weekend
My question before i start tearing anything apart is what size diameter pipe do i need to look for local before getting to a point of no return and having no ride to work...
i read in another thread the left and right side are different, is that the entire pipe or only near the head itself?
La Douche is offline
post #2 of 6 (permalink) Old 09-17-2011, 08:38 AM
1 5/8" I.D. They're not different diameter, IIRC, but one has a slight bend in it, which is corrected in the goat's belly, and in the Scootworks bypass kit.
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #3 of 6 (permalink) Old 09-17-2011, 08:41 AM Thread Starter
thanks for the help
post #4 of 6 (permalink) Old 09-17-2011, 05:57 PM
I always thought that the right side longer pipe was just a bit bigger around.
post #5 of 6 (permalink) Old 09-20-2011, 08:13 PM
Chucklehead
dragon159's Avatar
The right pipe has what I recall was a thicker wall but where the goat belly bolts they are both the same size. I used 1 3/4" pipe for my conversion and only had to flare the ends ever so slightly.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #6 of 6 (permalink) Old 09-22-2011, 02:23 AM
The right side pipe is bigger, but both collectors are the same size at the goats belly. There is a bend in the right pipe, and a short piece of flex pipe will cure that so that you can set the pipes at the right height to make them even.
RakerBill is offline
