Degoat, straight pipes? Rejet? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-16-2011, 10:56 PM Thread Starter
Noob.
So I took the goatbelly and tail pipes off of my exhaust today and it sounds amazing, so Im thinking of welding some pipes up with no crossover, and wrapping them up. My question is...would I have to rejet? Ive hear no, yes, and maybe.
ClassicFnAllen is offline
post #2 of 10 (permalink) Old 09-16-2011, 11:01 PM
Patriot Guard Rider
The DEUCE's Avatar
Nope!
I hope this helps.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 10 (permalink) Old 09-16-2011, 11:15 PM
Chucklehead
dragon159's Avatar
Shouldn't have to rejet but maybe adjust mixture screws.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 10 (permalink) Old 09-16-2011, 11:16 PM
And after a few years of riding like that you won't hear much of anything anymore.
You really only need to rejet if you alter the intake. (search "earshave")
Changing the exhaust the way you plan will however cause a small loss in power....so it will sound "amazing" , but get beaten by stock bikes.
post #5 of 10 (permalink) Old 09-17-2011, 10:18 AM
If only it had 6th gear..
DavesVulster's Avatar
These bikes rev too high on the highway to run them straight, just my opinion. I have a feeling you'll get sick of it after a short time (and have headaches) unless you don't do much higway riding but to each his own. I second KM's statement. Performance is much better with back pressure, as with most engines unless modified.
Good luck.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #6 of 10 (permalink) Old 09-17-2011, 10:47 AM
dirtrack650's Avatar
A high RPM V Twin like ours does sound nice with a 2 into 1 with a small muffler attached. A muffler just big enough to take the edge off the sound.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #7 of 10 (permalink) Old 09-17-2011, 11:49 AM
That sounds interesting. Does it still have a deep tone with a small muffler on it?
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #8 of 10 (permalink) Old 09-18-2011, 05:07 AM Thread Starter
Noob.
Originally Posted by The DEUCE View Post
Nope!
I hope this helps.
It does. Haha. Sent Im ready to snatch up those parts. Did you not get my PM?
Good luck.
I thought running straight pipes adds performance on n/a engines? What if I fabbed a cross pipe where the GB is?
post #9 of 10 (permalink) Old 09-18-2011, 12:11 PM
A crossover would be a good idea, several folks have done this.
The odd problem here is the stock system is in fact a "tuned" exhaust ... So getting more power over the entire rpm range with any alteration is almost impossible without sophisticated equipment.
Most of the power loss , and we are really only talking a few hp, when going to less restricted pipes is in the low end to middle. At or near redline open pipes work fine.... But not many run their bike constantly at redline.
post #10 of 10 (permalink) Old 09-18-2011, 01:16 PM Thread Starter
Noob.
Well...if I gotta lose a few hp, at least it wont sound so ricey anymore..haha. Ill just have to stick it out until I can afford to shave it.
