Coolant question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 09-09-2011, 12:49 AM Thread Starter
Coolant question
After stator rebuild and a new R/R the bike still overheated in a few miles. Earlier this year I replaced all the cooling system rubber parts and thermostat. I ordered a new radiator cap as the old one was a bit rough.
Flushed with Gunk super heavy duty engine flush and drained. I got out the infrared thermometer and carefully watched the temp at the top and bottom of the radiator, and the temp gauge. Also watched the fan to see when it kicked on. Refilled with fresh water and warmed up again. The fan turned on sooner (by about 4 needle widths) and stayed about 3 needle widths cooler than it had before. Temperatures dropped about 10 degrees at the top and bottom. My take is the sensors for temp and fan switch were coated with scale.
I need to pick up antifreeze tomorrow and wanted to throw this out as I didn't see it when I searched this forum. Seems some folks are using Honda Type 2 antifreeze from car dealerships in other water cooled bikes. Its blue colored which would make it easier to see in the overflow tank. I see mixed reviews on Dexcool. I don't want to get bent over at the Kaw dealer if I can avoid it. Has anyone had any experience with the Honda Type 2 in a VN750?
sparks54 is offline
post #2 of 16 (permalink) Old 09-09-2011, 09:07 AM
JM2001's Avatar
Any 50/50 mix of antifreeze which says suitable for aluminum engines on the container is ok. I get mine at Walmart, it's green and called SuperTech Antifreeze and Coolant.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 16 (permalink) Old 09-09-2011, 10:07 AM
flitecontrol's Avatar
I agree with JM2001.
Ethylene glycol is the same stuff no matter the color or whose name is on the container. There may be different products that perform differently, but basic antifreeze is the same. Read the ingredients label to confirm.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 16 (permalink) Old 09-09-2011, 11:40 AM
93VN750's Avatar
If you are not worried about freezing temps, I'd use Red Line Water Wetter and distilled water. Much better heat transfer than any glycol solution.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 16 (permalink) Old 09-09-2011, 01:34 PM
JM2001's Avatar
Jon
Why? If you are running a 50/50 mix it will lower your temperature by only 8 degrees. If you are running 100% water, then it will lower it by 18 degrees. No one should be running 100% water in the first place. I don't see the need for it. JMO
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 16 (permalink) Old 09-09-2011, 01:49 PM
Member? ... check.
ZCraggRatt's Avatar
The use of distilled water is key to the prevention of calcium scale buildup on the coolant system components. Even top off water should be distilled or at least RO.
Aluminum safe mix is a given.
my2cents.
~~C8>
ZCraggRatt is offline
post #7 of 16 (permalink) Old 09-09-2011, 01:52 PM
There are a few iron alloy pipes in the system. Will they rust???
post #8 of 16 (permalink) Old 09-09-2011, 05:52 PM
93VN750's Avatar
Has your temp gauge never gone to or past the red line? Mine used to, does not since I switch to this. It always hot here in Florida so I take every advantage I can. Bike has a thermostat so it will not run too cold. Why wouldn't you want to have it run as cool as possible?
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #9 of 16 (permalink) Old 09-09-2011, 05:55 PM
93VN750's Avatar
It's not rust you are concerned with. As stated above "The use of distilled water is key to the prevention of calcium scale buildup on the coolant system components.". It's helps to keep your system flowing as much as it can without restrictions.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #10 of 16 (permalink) Old 09-09-2011, 08:05 PM
JM2001's Avatar
Jon
Never got close to the red line. Even in 98 degree temperatures my gauge never went past midpoint. I'm glad it works for you but a 8 degree decrease over a 50/50 mix shouldn't make that much difference.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
