Starter motor spins, tach revs, no engine sounds - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 09-03-2011, 11:08 PM Thread Starter
keith68's Avatar
OK, I've got a 97 VN750 that has been running fine (26,300 mi) only problems lately have been battery issues in the Texas heat.
Today I went to start it (about 3-5 seconds) and initially the motor cranked, but didn't fire. On my second start attempt, I only heard the whine of the starter and the tach revved up to about 5000, but from the sound, the motor wasn't cranking. I put it in 5th gear and rocked it back and forth to see if something might be frozen and it didn't appear to be. I removed the starter to test it off the bike and it spins fine. The gear that the starter pinion contacts looks to be fine. Have I sheared something off inside the engine? Where does the tach pick up its RPM reading from? Any ideas?
keith68 is offline
post #2 of 5 (permalink) Old 09-03-2011, 11:11 PM
Charge the batt or jump start the bike. It may just be a low batt.
post #3 of 5 (permalink) Old 09-03-2011, 11:50 PM Thread Starter
keith68's Avatar
Yeah this probably should have been in the electrical thread.
I re-filled the battery yesterday and had it on the charger all night, so it should have been ok, but I have suspected for a while that I just need to replace it. She was due for an oil change anyway, which I had to drain to remove the starter, so I need to get a new filter and re-fill it before attempting the jump start.
keith68 is offline
post #4 of 5 (permalink) Old 09-04-2011, 01:45 AM
Since you are still using a wet battery, when you change it out, get a Maintenance Free AGM like this Deka:
http://cgi.ebay.com/ebaymotors/Deka-...item3eee173adb
It will cure a lot of starting problems, especially if you get a set of NGK Iridium spark plugs, number DPR7EIX-9.
post #5 of 5 (permalink) Old 09-12-2011, 11:22 AM Thread Starter
keith68's Avatar
Just wanted to update....you guys were dead on! Bought a new sealed battery over the weekend, changed the oil and filter and she fired up on the first push of the button. Many thanks for the advice.
keith68 is offline
