stator or something else ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 09-03-2011, 04:39 PM Thread Starter
Hi I have a 1993 vulcan 750 which I have already had the carbs redone and gas tank gaskets done but now when I went to start it the other day it was a bit harder. Today i tried to start it and like the battery was almost died, I put an volt meter on it and it was 12 volts so I had to boost it and took a bit but got it started, then I put the volt meter on the battery when it was running it was the same volts ( 12 v) so I am thinking its the stator gone bad. But I am wondering is there any fuses connected to the charging system.
scubadiver is offline
post #2 of 9 (permalink) Old 09-03-2011, 08:19 PM
ifixf18s's Avatar
I have a 2005, but from what I understand the bike hasnt changed much. There is a fuse thats inline with the positive wire that goes to the battery from the R/R, but its the main 30A fuse.
From what I understand this bikes electrical system could of been engineered a bit better. The charging system when the bike is running dont put out much at all untill 3000-4000 RPM's. So check it again at the higher RPM's and let us know what you get. Should climb up to 13.5 - 14 VDC.
For the most part the charging system has nothing to do with how the bike starts and runs. With that said, if your have a good strong battery the bike would start and run just fine untill the battery ran down enough not being able to support the ignition. Just like the alternator going bad in your car.
ifixf18s is offline
post #3 of 9 (permalink) Old 09-03-2011, 10:11 PM
ifixf18s is right, at an idle speed of 1100rpm the OEM vn750 stator and reg/rec does not charge. As the rpms climb the headlight should get brighter, and at 4-5K rpms the voltage should climb close to 15 volts, but should not ever exceed that level.
The charging system does include the 30 amp main fuse in the junction box under the left side cover.
post #4 of 9 (permalink) Old 09-03-2011, 11:16 PM
Member? ... check.
ZCraggRatt's Avatar
The battery is charged thru that main 30 amp fuse, but the fuse is good. The starter relay won't pull in with out it. If all your wiring looks to be in good order, no loose or burnt connections, I think it's time to do the stator tests.
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #5 of 9 (permalink) Old 09-12-2011, 02:44 AM
stator is out
what this the best stator to buy? i have a vulcan 1985 700
ninja54 is offline
post #6 of 9 (permalink) Old 09-12-2011, 09:37 AM
flitecontrol's Avatar
Avoid Rick's stators like the plague. A rebuilt stator from Tim Perrot Enterprises (here's their ebay ad: http://cgi.ebay.com/ebaymotors/motor...Q5fAccessories) is the best. Even better than OEM. You send them a rebuildable stator and they send you a rebuilt one.
Someone mentioned that emailing Tim was the route to go (http://www.tpe-usa.com/). Think they said it was cheaper than the ebay price dealing directly with them.
Update: I see you posted this question twice (and got basically the same answer). Please avoid doing this in the future. Your question will be answered, and folks like me won't waste their time duplicating an earlier response.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 9 (permalink) Old 09-13-2011, 12:04 AM Thread Starter
update: after I tried to do a volt test to no good luck, called my motor bike shop and took it in and they are looking at it. Will post after i get the bike back, I hope it not too much.
post #8 of 9 (permalink) Old 09-18-2011, 05:07 PM Thread Starter
update
Hi everyone first off I like to thank all of you that helped with my problem with my bike. After I took the bike down to get it looked at they found out that the stator grounded out and needs to be replaced.
post #9 of 9 (permalink) Old 09-19-2011, 06:34 PM Thread Starter
Hi everyone got my bike back today. As it turned out it is the stator and it was burned from shorted out ( guess it was from a on the border line bad stator from factory ) Oh well now it has a new stator so should no need to change it never again ( I hope not ).
Just glad that I can get back on the road cause of the season is almost over.
