Goop - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-01-2011, 06:46 PM Thread Starter
Concert connoisseur
wib714's Avatar
Goop
anyone have any experience with it. I have a craftsman weedeater with a plastic gas tank, it cracked. its only 15 bucks for a new one plus another 15 shipping. it cracked where it bolts on to the weedeater in both locations and was leaking gas everywhere and would not run cause it was sucking too much air. I bought some "Goop" and coated it and now its working like a champ and not leaking.
so now I'm wondering, when I changed my sight glass cover gasket I apparently didnt do a good enough job cause I have a pretty good oil leak now, about a quart every couple weeks but it makes a mess out of my bike, I hate to tear it back down right now cause no garage and money but am wondering if I coat the outside of the cover all the way around if this my stop or significantly slow my leak. it dries clear so not to worried about seeing it on there and it wouldnt be that noticeable down there, possibly the stator cover too. any thoughts or experience with it anyone?
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 4 (permalink) Old 09-01-2011, 07:04 PM
The only "goop" I am aware of is the hand cleaner and the waterproof sealant. If you mean the latter, it is not gasoline freindly.
You have link to the product you are talking about?
post #3 of 4 (permalink) Old 09-01-2011, 07:12 PM Thread Starter
Concert connoisseur
wib714's Avatar
here you go, its holding on my gas tank for now!
http://www.biosafe-inc.com/all_purpose.htm
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 4 (permalink) Old 09-01-2011, 07:30 PM
Yep, same stuff I used to glue the rubber on all my floorboards. It is not solvent proof however, so if gasoline gets on it , it may start to deterioate.
I know laquer thinnner will soften it...but never spilled gas on it..so no real clue if it would be an issue.
