Help with ACCT - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-29-2011, 02:31 PM Thread Starter
Help with ACCT
So I don't know much about bikes at all, had the bike at the shop and they were unsure of the noise. It's coming from the front, clanging/tapping that will come and go. From reading online I'm guessing it has to do with the ACCT, I understand the concept of such but am unaware of where it's located to be able to do the so called "trick" to see if it has gotten stuck or what. Does anyone have a pic or something of it's location so I know what I'm looking at? Thanks!
When Chuck Norris heard news of the VN 750, he decided to become one!
2004 750 Vulcan
-Marbled
-AGM M/F Battery
-Corbin seat
Unclemoney is offline
post #2 of 10 (permalink) Old 08-29-2011, 02:42 PM
Here's a pic of the left side of the engine. You can see the acct in the center of the "V" at the bottom of the front cylinder.
In this pic it is located just to the left of the number tag. On your bike it will be hidden by the coolant resivoir.
Hope this helps.
post #3 of 10 (permalink) Old 08-29-2011, 02:43 PM
Here is a close up of a modified rear acct, just to give you an idea of position.
post #4 of 10 (permalink) Old 08-29-2011, 02:48 PM Thread Starter
Thanks! Now to go outside and try this "gambo" trick and see if it helps out at all
2004 750 Vulcan
-Marbled
-AGM M/F Battery
-Corbin seat
post #5 of 10 (permalink) Old 08-29-2011, 03:32 PM
TOC 's MCCT comes with instructions. They work great !
post #6 of 10 (permalink) Old 08-29-2011, 05:40 PM Thread Starter
Something I'm thinking of doing! I messed with the screw and it's running fine now, but from what I've read the ACCT is a horrible design and seems to be a common problem!
2004 750 Vulcan
-Marbled
-AGM M/F Battery
-Corbin seat
post #7 of 10 (permalink) Old 08-29-2011, 07:16 PM
dirttrack650 made the simplest modification by drilling a hole in the ACCT, and tapping it for a set screw.
See post 29 for a picture with a small bolt installed:
https://www.vn750.com/forum/showthrea...t=17917&page=3
If the bolt were replaced with an Allen head setscrew, it would be virtually unnoticeable to anyone looking.
post #8 of 10 (permalink) Old 08-29-2011, 10:51 PM
Concert connoisseur
wib714's Avatar
theres a link in my sig to build your own for less than 6 bucks that you can revert back to acct at any time if wanted, I've got I'm roughly guessing quite a few thousand miles out of mine now with no leaks or problems. and my 14 year old could follow the instructions, it will take you about a half hour tops!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 10 (permalink) Old 08-29-2011, 10:53 PM
UM love your ChotorNycle. I noticed bugs don't dare hit his face! -jim
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
Did I miss anything?
Kayakrazy is offline
post #10 of 10 (permalink) Old 08-29-2011, 10:54 PM
Concert connoisseur
wib714's Avatar
also when putting the cap screw back on, only snug it, the threads are very soft. you can take the cap screw off when the engine is running on the front and look down in it. if you see the slotted screw jumpnig aroung when you hear the ticking, it is the culprit!
hope that helps!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
