I might have just killed my baby - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-13-2011, 03:37 AM Thread Starter
I did a simple oil change including the filter on an 04 vn750, not my first either. Although i brain farted the order of the drain plug assy. reversed the spring and the washer. Drained again and corrected.
My problem is that once I started the motor I noticed the oil didn't leave the sight glass. I could see the same size bubble I had started with. the oil light stayed on. I hope that my issue is just that I didnt prime the filter enough. so she sits overnight. If that doesnt work i am going to get a new filter, prime it correctly, and refill oil.
So... my question to ya'll is If these things don't fix the problem of oil not dropping level in sight glass (IE oil pump not pumping) what other if anything could i do on the cheap? Or am I stuck with splitting the case for diagnosis?
You guys have been a great help in the past!!!!!
2004 Vulcan 750
Mine on Feb 2011
with 14,000mi
now 18,000mi
bone stock and
Lovin it
l3rice is offline
post #2 of 9 (permalink) Old 08-13-2011, 05:51 AM
Concert connoisseur
wib714's Avatar
unscrew the filter while running slightly enough to let some air in and burp it and retighten and see if the light goes out!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 9 (permalink) Old 08-13-2011, 07:17 AM Thread Starter
thanks wib I'll give that a try. Anything is better than a complete tear down right now. It's not that I cant do the work. I just dont have the funds or the time or money to rebuild.
2004 Vulcan 750
Mine on Feb 2011
with 14,000mi
now 18,000mi
bone stock and
Lovin it
l3rice is offline
post #4 of 9 (permalink) Old 08-13-2011, 08:26 AM
Crobins365's Avatar
If it was running fine before you did the oil change, chances are it really is just an air bubble. Follow wib's suggestions and let us know that all's well.
C
Crobins365 is offline
post #5 of 9 (permalink) Old 08-13-2011, 08:55 AM
JM2001's Avatar
X2 According to Ma Kaw if the light doesn't go out at 1400 rpms after changing the oil, you might have a problem. You may not have gotten the engine to that speed.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 9 (permalink) Old 08-13-2011, 11:31 PM Thread Starter
bike burped and all is well
thanks all
2004 Vulcan 750
Mine on Feb 2011
with 14,000mi
now 18,000mi
bone stock and
Lovin it
l3rice is offline
post #7 of 9 (permalink) Old 08-14-2011, 07:03 PM
Concert connoisseur
wib714's Avatar
so much easier than splitting the case! LOL glad you are good to go!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #8 of 9 (permalink) Old 08-14-2011, 10:18 PM
lphernan's Avatar
Gotta love this site.
Louie
1995 VN750 - Work in Progress
2001 BN125 - Learning Bike
2004 GL1800 - All Done
lphernan is offline
post #9 of 9 (permalink) Old 08-15-2011, 07:16 AM Thread Starter
I know right. Who would have guessed my baby needed a good ol fashioned burping. Thanks wib
2004 Vulcan 750
Mine on Feb 2011
with 14,000mi
now 18,000mi
bone stock and
Lovin it
l3rice is offline
