torq specs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-06-2011, 01:53 AM Thread Starter
torq specs
What are the torq specs for the stator bolts? Also what are they for the left outer cover, and is there a certain order? The other spec I need is for the mcct, went to bolt down the unit and snapped the bolt. Was able to pull the bolt out of the motor, so I need to order a new one. What is the part # for those?
1992 Vulcan 750.
Ear shaved and re-jetted.
theone2043 is offline
post #2 of 4 (permalink) Old 08-06-2011, 01:13 PM
Torque stator bolts to 9 ft/lb as per Cymer manual.
Can`t find any torque specs for engine side covers, but if they are 6mm fasteners, Roach says repeatedly in his rebuild videos that 69 in/lb is the standard recommenation unless otherwise specified. Thanks Roach .
I think that cover has 13 bolts, so I would tighten them in three steps in a criss-cross pattern similar to tightening lug nuts on a wheel.
1- finger tight
2- 60 or 65 in/lb on the first round with the torque wrench
3- 69 in/lb on the final round
6X18 mm stud shown for mounting ACCT in this link:
http://www.bikebandit.com/houseofmot...m4555#sch47969
92004: STUD,6X18
856631
(1556-001) Enter
0-99 $2.98
post #3 of 4 (permalink) Old 08-06-2011, 01:41 PM Thread Starter
I just got a ft/lbs wrench the other day, so could I do 6 ft/lbs and be fine?
1992 Vulcan 750.
post #4 of 4 (permalink) Old 08-06-2011, 03:11 PM
Probably,............ but I would buy an in/lb wrench as soon as possible if I were going to be doing more work on the bike in the future.
I think mine cost less than $30 at Princess Auto, the Canadian equivalent of Harbor Freight.
