Running Hot - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 07-10-2006, 10:11 PM Thread Starter
REDRIDER
danield's Avatar
Running Hot
I Have A 2006 Vn750 With 3500 Miles. The Other Day, I Drill Holes In The Muffler Tip For A Different Sound. While Coming From Work At 60-65 Mph The Tempature Gauge Starting Going To The Red And I Also Starting Loosing Power. Pulled Over For About 5 Minutes To Let The Bike Cool. Ran Fine After That. Didn't Like The Sound So Covered The Drilled Holes. Is The Bike Designed To Shut Off When The Tempature Reachings The Red Zone? Don't Know Why It Got Hot Unless It Was The Additional Holes In The Muffler Tips And I Didn't Alter The Air/fuel Mixture To Compensate For The Difference. Any Thougths On This Is Appreciated.
danield is offline
post #2 of 13 (permalink) Old 07-11-2006, 05:33 AM
Rubline's Avatar
Just because the bike is new doesnt mean that all the fluids are at the correct level. Did you check your coolant? I would guess that its low.
Rubline is offline
post #3 of 13 (permalink) Old 07-11-2006, 05:51 AM
That's a good thought.
Many dealers aren't known to be the sharpest tools in the shed !!
Maybe check the themostat too.
post #4 of 13 (permalink) Old 07-11-2006, 05:57 AM
Ernie's Avatar
Send a message via MSN to Ernie
Does it ever happen in slow moving traffic. If so, is the fan cutting in?
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #5 of 13 (permalink) Old 07-11-2006, 11:27 AM
fergy's Avatar
Not likely that the holes you drilled caused anything like overheating. Now if you somehow plugged your exhaust it would have an effect, but you would have felt a serious loss of power. You covered the holes "after" this incident?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 13 (permalink) Old 07-28-2006, 06:17 PM
Benjammin'
BSkaggs513's Avatar
About those holes....
Does drilling holes in the exhaust cause the loss of power or torque folks claim to see when degoating? I want just a little more sound, but I don't want any other implications or problems from drilling.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #7 of 13 (permalink) Old 07-28-2006, 08:11 PM
Drilling holes in your exhaust will not cause a decrease in power, removing the goats belly can take away a very slight amount, hardly noticable unless you are launching hard.
Woody is offline
post #8 of 13 (permalink) Old 07-30-2006, 10:40 PM Thread Starter
REDRIDER
danield's Avatar
Took Bike To Dealer. Haven't Gotten It Back Yet. First Response From Service Manager About Bike Overheating Was Maybe It Was A Vapor Lock. Plenty Of Coolant In Overflow, Oil Change Recently. Bike Has Hesitation Also. Put In Sea Foam, No Change. Told Dealer To Check For Carb Syn And Check Air/fuel Mixture. Maybe This Will Help. Plan On Buying V&h Pipes Later On. Info From Forum Appears Thatthis Is The Best On The Market For The Vn750. Will Keep You Updated On Status.
danield is offline
post #9 of 13 (permalink) Old 07-30-2006, 11:27 PM
Once Banned
cegodsey's Avatar
Off the subject. I've seen misspellings and the like, but I've never seen anyone capitalize the first letter of every word. What's up with that?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #10 of 13 (permalink) Old 07-31-2006, 11:17 AM Thread Starter
REDRIDER
danield's Avatar
I don't know why I capatilized the letter of each word. Got your attention though.
danield is offline
