Killed my engine... BAD - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 37 (permalink) Old 07-31-2011, 12:19 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
Unhappy Killed my engine... BAD
So back on March 12th I was out on a group ride. We were riding VERY spiritedly: I had it pegged at about 105. All of a sudden I had a loss of power. Pulled to the side of the road, and as I slowed the engine died. Started it back up and there was a terrible sound in the front cylinder. Tried to limp it back to civilization, but didn't make it very far before there was a loud thud/crunch and the engine seized.
Since then, I hadn't gotten around to finding out what the problem was, simply because I just didn't want to know/see how bad the damage is.
Well, I finally started taking it apart this week. And it's just as bad as I feared.
Drained the oil and found a lot of metal flakes in the oil screen. That's a bad sign:
Got the engine out (God it's such a pain in the ass to remove the engine!) and took off the valve cover. Immediately saw that two rocker arms were not on their valves. Not sure if that happened before or after I removed the engine.
Pulled off the cylinder head, and the badness is immediately obvious:
Get the cylinder off, and it's even worse:
Plenty of metal pieces down in the bowels of the engine too:
Looks like I've got my work cut out for myself to get it going again. But I know I can get it done. Just a matter of time, money, and effort. Worst part is that I'm off the road during the prime riding season. Sucks.
I'll update with more photos as I keep going.
DaveT319 is offline
post #2 of 37 (permalink) Old 07-31-2011, 01:17 AM
OUCH, sorry for your bad luck, good pics though.
post #3 of 37 (permalink) Old 07-31-2011, 08:04 AM
Concert connoisseur
wib714's Avatar
so sorry to see that, good luck with the rebuild!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 37 (permalink) Old 07-31-2011, 08:06 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #5 of 37 (permalink) Old 07-31-2011, 08:16 AM
That sure left a mark! Hey can I use your VN900 seat while you re-build? (Figured that you needed some humor cause you got to be crying deep down inside.)
CW-4 is offline
post #6 of 37 (permalink) Old 07-31-2011, 10:11 AM
New head, piston, sleeve rod, bearings, and that just what we can see. Might be time to part it out and buy a new bike.
Do you know what happened? Did you throw a cam chain or something?
No more Vulcan
New ride 2012 Victory hammer 8 ball
Stage 1 with Cobra 2 into 1 exhaust.
Devil_Hwy is offline
post #7 of 37 (permalink) Old 07-31-2011, 01:12 PM
Wow Dave, that`s a kind of bad luck, good luck story.
Bad luck that the engine broke, but good that it didn`t seize solid while you were traveling at a buck five.
That would have made the ride so much more...mmmmm...interesting....than you needed.
I will be watching to see what else you discover here, as to why it broke in the first place.
Good luck with a speedy and solid fix.
https://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would.html
post #8 of 37 (permalink) Old 07-31-2011, 03:27 PM
ifixf18s's Avatar
Curious here, So what does the tach show when your going 105 MPH?
ifixf18s is offline
post #9 of 37 (permalink) Old 07-31-2011, 03:43 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Welcome to the Club..........
The journey begins:
https://www.vn750.com/forum/showthread.php?t=10466
The journey continues:
https://www.vn750.com/forum/showthread.php?t=10664
The journey ending:
https://www.vn750.com/forum/showthread.php?t=11063
__________________
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #10 of 37 (permalink) Old 07-31-2011, 04:01 PM
KidChaos's Avatar
for me, roughly 7K
KidChaos is offline
