right side pipe is chugging a bit?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 07-29-2011, 02:11 AM Thread Starter
knees in the breeze!!!
Tofer76's Avatar
ok when at a idle my right side exhaust pipe is kinda blubering a bit when the left is a constant rumble
almost sounds like the front cyl is either missing or got too much fuel not sure which
it sounds fine to me going down the road but then again its de goated and one side might be drowning out the other
i have ran the air mix screw on the left side all the way in and then out to 4 turns and it still does it it should be the same on both pipes right?
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #2 of 12 (permalink) Old 07-29-2011, 10:38 PM Thread Starter
Tofer76's Avatar
nobody has any ideas?? really??
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #3 of 12 (permalink) Old 07-30-2011, 12:03 AM
If only it had 6th gear..
DavesVulster's Avatar
4 turns out on those idle mix screws is too much in my opinion. Should be 2.5 to start with then make very small adjustments from there. I'm talkin 1/4 - 1/2 turn and wait a couple of seconds for change then another 1/4 - 1/2. I got mine to idle beautifully by going slowly with the adjustments. I'm probably at around 2 3/4 on one and 3 on the other but I also changed my jets. If you're running the stock air cleaners (ears) then yours would probably be a little less. You asked if they should be the same...They don't need to be exact but they should be fairly close on an engine in decent condition.
Sometimes people run the idle too low on these v twins because they sound cool but they're not designed to idle low. Oil pressure will suffer and it won't charge right. May even foul up a bit if too long, like if you're in traffic a lot. They're supposed to idle at 1100. Just putting it out there in case, since you haven't had it long.
When it's idling does it smell if you stand behind it? That's a good indication that it's rich. Hope this helps. Update when you can.
Dave
DavesVulster is offline
post #4 of 12 (permalink) Old 07-30-2011, 02:23 AM
Check the balancing of the carburetors. It may idle almost entirely on the rear cylinder.
pappa is offline
post #5 of 12 (permalink) Old 07-30-2011, 08:45 AM Thread Starter
Tofer76's Avatar
how do i check the carb balance
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #6 of 12 (permalink) Old 07-30-2011, 01:06 PM
How to sync carbs from Vulcan Verses:
https://www.vn750.com/forum/showthread.php?t=1084
How to build an inexpensive manometer/carb sync tool:
https://www.vn750.com/photopost/showp...o=2399&cat=657
post #7 of 12 (permalink) Old 07-30-2011, 02:10 PM
fergy's Avatar
At a glance, sounds like your idle jet may be clogged a little on that side. Have you been running seafoam?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 12 (permalink) Old 07-30-2011, 02:31 PM Thread Starter
Tofer76's Avatar
no seafoam i have some tho how much per tank
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #9 of 12 (permalink) Old 07-30-2011, 05:48 PM
fergy's Avatar
For this issue I'd try and fill the carbs with straight seafoam and let it sit at least a day or two. You can pull off the fuel hoses from the petcock and load the carbs from there. That's what I'd do. Once you've done that you can drain the carbs from the drain screws on the bottom of the bowls, then button things back up and put about 1/3 or 1/2 a can of seafoam in the tank of gas and ride it like you stole it for a day or so and about 90% of the time it will be fixed. The other 10% have to pull the carbs and clean them.
As a preventative measure, about once a month I put some seafoam in a full tank of gas on my bike, about 2-3 oz. I keep a bottle in my saddlebag so it is always around. It's great stuff. There's another thread on here right now talking about the miracle of seafoam. Check it out here.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #10 of 12 (permalink) Old 08-08-2011, 02:46 AM
cjcoburn's Avatar
Hi Tofer76,
I have a similar issue and have been following this thread...so where did things end-up with this problem? Did you get it straightened out? If so, what worked for you?
Best Regards,
Chris
Arvada, CO
VROC No. 7348
1986 VN 750 Ebony
cjcoburn is offline
