Carb adjustment has no effect on popping - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-09-2006, 05:27 PM Thread Starter
Rubline's Avatar
The subject says it all. I've plugged the reed cover and im sure that no air is getting by the plug. I installed the HD crush gaskets and tightend both side equally to the torque specs. I've tightend the rubber boots leading to and from the carbs. The problem is with the front cylinder only. The rear cylinder has no popping at all with the mix screw turned out 2.5 turns.
No matter what mix screw position I am getting terrible popping from the front cylinder. Any thoughts out there? Forgot to mention pipes are V/H Cruzers
Rubline is offline
post #2 of 11 (permalink) Old 07-09-2006, 05:33 PM
I tryed all that too and no good only pop's like you said
front cyl.I guess we live with it.......
vulcan460 is offline
post #3 of 11 (permalink) Old 07-09-2006, 06:25 PM
Geek
rnewell's Avatar
Same here. I've got my screws out about 3 3/4 turns. The last quarter turn actually brought the idle speed up about 200 rpm. The last quarter turn also reduced the popping, a little.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #4 of 11 (permalink) Old 07-09-2006, 09:06 PM Thread Starter
Rubline's Avatar
I guess ill call V/H tomorrow and see if they can come up with a solution. I've read somewhere that the jets in the carbs were modified and the popping was eliminated. Its embarrasing to have the bike popping like that. If the popping cant be eliminated to my likeing, I'll go ahead and install the stock setup.
Rubline is offline
post #5 of 11 (permalink) Old 07-09-2006, 09:16 PM
Well you can look at it this way ,we have a one of a kind bike.
post #6 of 11 (permalink) Old 07-09-2006, 10:36 PM
It is very possible that with changing the exhaust that you'll need to re-jet the carbs.
I'm still trying to get my dirtbike carb set just right. They can be tricky !
post #7 of 11 (permalink) Old 07-09-2006, 10:57 PM
Rejetting might stop it but unless you increase the intake of air you aren't going to gain much although V&H recommends (I think) 1 size larger idle and main jets. It should be on the instruction pages, if not call there tech line.
Woody is offline
post #8 of 11 (permalink) Old 07-09-2006, 11:24 PM
Exclamation Backfireing
I had my bike in the shop and the shop mechanic said that the reason why it was backfireing when coasting was b/c there is a little valve or something that had to be replaced...i forget but he did what ever he had to do and it stopped...
750 FREAK is offline
post #9 of 11 (permalink) Old 07-10-2006, 01:15 AM
That's good news !!!
Probably the reed valve.
Glad ya got it fixed !!
post #10 of 11 (permalink) Old 07-10-2006, 06:56 AM Thread Starter
Rubline's Avatar
Hey Freak,, any chance you can call your dealer and see what he did?
Rubline is offline
