ACCT set screw to lock it in place - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-15-2011, 09:45 AM Thread Starter
dirtrack650's Avatar
Thumbs up ACCT set screw to lock it in place
This is working fine after 200+ miles. The weather has turned crappy again so bike is stuck in garage - don't feel like getting wet.
The screw is a 10-24 thread that stops the ACCT adjuster from moving due to a weak spring.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 5 (permalink) Old 07-15-2011, 09:53 AM
Interesting solution. Do you get oil leaking from the rear one? Being at a downward angle & all.
post #3 of 5 (permalink) Old 07-15-2011, 10:17 AM Thread Starter
No need to do rear yet
The rear is quiet and working as it should so it's stock. I did use some thread locker acting as a sealer. Wish I would have done this years ago - I've owned the bike 10 years.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #4 of 5 (permalink) Old 07-15-2011, 01:26 PM
Is that a nylon tipped screw? Or just a standard steel tip?
A standard steel screw might dig into the internal piece and not allow for fine adjustments.
If it wasn't for time, everything would happen at once!!
Flap1 is offline
post #5 of 5 (permalink) Old 07-15-2011, 01:56 PM Thread Starter
The pic shows a stainless screw as a test. I have a true steel set screw in now.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
Tags
acct , cam chain , mcct
