Thermostat??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-06-2011, 09:51 PM Thread Starter
Thermostat???
My 85 VN700 dos no have the thermostat housing on it the previous owner removed it and replaced it with just straight hoses....is it ok to run that way or should I replace the original set up?
hoggs750 is offline
post #2 of 4 (permalink) Old 07-06-2011, 10:03 PM
Crobins365's Avatar
Your engine will run cooler than normal if you're running fluid through it full-tilt all the time. Probably not the worst thing for these bikes, particularly in the summer, but generally the recommendation is to run at the specified temps (and let the thermostat determine how to keep the engine block in that range). That said, it's easy enough to find second-hand thermo housing units here and on eBay for very little $$.
C
Crobins365 is offline
post #3 of 4 (permalink) Old 07-06-2011, 10:10 PM
Bronson's Avatar
It should not hurt anything to run without a thermostat. It will take longer to warm up the engine on cooler mornings. As a resullt, fuel economy will drop until warm up, and emissions will be higher.
On colder days; around here I will ride until the temps are below 30 degrees in the mornings, the bike will probably not even register on the temp gauge unless you have a themostat in place in the system.
If I could find a replacement I would reinstall another one if mine were gone.
Just my opinion. As Said above, no harm done either way.
Bronson
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #4 of 4 (permalink) Old 07-06-2011, 10:15 PM Thread Starter
ok thanks for the info guys
hoggs750 is offline
