engine stops running with tight right turn - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-03-2006, 08:46 PM Thread Starter
When I am parking the bike (normally in nuetral) and turn the wheel hard to the right to back into a space, the engine dies. It is almost like the 'Kill' switch is flipped or the engine goes into gear and kills the engine.
I have installed a new handle bar and dropped it down a little from the 'chopper' look and don't know if that has had an effect on the cable lengths.
Has anyone run into this problem and is there a solution?
Thanks.
K-Lo
K-Lo is offline
post #2 of 6 (permalink) Old 07-03-2006, 10:27 PM
I had my ignition switch replace only 2 weeks after I got it. If the harness is not correctly routed it pulls the switch contact open. Seems that I have also read about this problem in the verses. If you are mechanically inclined you might be able to fix this yourself.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #3 of 6 (permalink) Old 07-04-2006, 01:49 AM
Could be any number of things grounding out.
How old is the bike?
Have ya checked that all bulbs are still working?
Any fuses blow when this happens?
Next time you have the bike running, turn to the right and listen closely for any sounds of electrical arcing to try and track it down.
post #4 of 6 (permalink) Old 07-10-2006, 08:19 PM Thread Starter
thanks for your help. I re-arranged and adjusted the slack in the cables from the kill switch and it seems to have corrected the problem.
K-Lo is offline
post #5 of 6 (permalink) Old 07-11-2006, 05:41 AM
post #6 of 6 (permalink) Old 07-11-2006, 11:32 AM
Loran in Npvl IL's Avatar
With you being the expert, please come on over and fix mine or I will be at the gathering next week and you can help fix it there
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
