Seafoam Spray?? Where to putter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-09-2011, 07:24 PM Thread Starter
ryanmitchy's Avatar
I bought some seafoam from a local auto store and they only had the spray that is used for 2 and 4 stroke engines and i read the instructions but i dont get it. Anyone use the spray and can show or tell me what i need to do?
ryanmitchy is offline
post #2 of 7 (permalink) Old 06-09-2011, 08:12 PM
The Seafoam spray seems to be a fairly new product.
We have all been using Seafoam in a bottle that pours into the tank.
Here is a link to Seafoam`s homepage where you can learn how to use all their products.
http://www.seafoamsales.com/
post #3 of 7 (permalink) Old 06-09-2011, 08:32 PM
Patriot Guard Rider
The DEUCE's Avatar
Here's a video at Youtube
http://www.youtube.com/watch?v=Vqs8Q...layer_embedded
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 7 (permalink) Old 06-10-2011, 01:06 AM
I'd say if you're having carb problems, then pull the drain screws out of the floats and spray some in there. Other than that, I'm not sure where else unless you pull the ears off and shoot some into the air intake.
post #5 of 7 (permalink) Old 06-10-2011, 01:14 AM
abyssdncr's Avatar
I used to use the deep creep on my old KZs as an annual valve treatment. Take the vacuum line/cap off the vacuum port of each carb/manifold and spray 2-3 second bursts through the port. Bikes bogs & smokes like crazy while it's burning up the Seafoam cleaning off your valve heads, but after half a dozen squirts per cylinder, the smokiness mellows out and I call it good.
Doesn't do a dang bit of good if you're trying to clean your carbs though. If you can get to any of the jets to spray them out (and you can pretty easily) - use carb cleaner instead...that's what it's for.
'98 VN750, Mustang Seat, F&S Engine Guards, Highway pegs, Pro-Tac backrest, Harley 58121-85B windshield lowers, Autometer 3391 voltmeter, ACCT to MCCT, pickup coils at 0.020", Coasters, National Cycle N2220, Vista Cruise Universal, Single Filter Ear Shave, Givi Monokey Sidebag Mounts, Givi E21 side bags, Knifemaker style turn signal relocation, helmet locks relocated.
abyssdncr is offline
post #6 of 7 (permalink) Old 06-10-2011, 08:33 AM
Scootergptx's Avatar
Could have used the spray on my old Ranger. Throttle body intake was sideways instead of straight down. So when I wanted to shoot some through there, I went to the dollar store and bought a cheap plastic spray bottle. Poured the seafoam in that, and had spray seafoam.
If you do that, be sure to mark the bottle you use as poison. Got little ones in the house that will play with the water spray bottle I keep by the grill.
Global warming? So what if my kids never see a polar bear. I never saw a dinosaur and I'm ok.
Scootergptx is offline
post #7 of 7 (permalink) Old 06-10-2011, 04:38 PM Thread Starter
ryanmitchy's Avatar
Well thats what i tried to do was take the intake off and spray down that but its impossible to spray it 1/4" from the throttle body cause the both meet in the middle and go down a chamber somewheres.... i have an apt to get a service done tuesday ill have to wait cause the bikes not starting now.. I shoulda sold it before this B.S started going wrong.....
