? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 34 (permalink) Old 05-30-2011, 08:12 PM Thread Starter
mpeace's Avatar
Ok I'm confused at what happened to my bike,I changed the oil and put in rotella 15w40 but after starting it a few times it is now locked up,I did notice after the oil change the motor was noiser and then I started it Saturday morning and it started tapping then I started it that night and it shut off and now it is locked down.
mpeace is offline
post #2 of 34 (permalink) Old 05-30-2011, 08:45 PM
'03 VN750 "Rosie"
bstew7890's Avatar
How much oil did you put in? What does the sight glass show? Did you put back the screen, spring, and washer behind the drain plug? Any chance something fell into the oil filler hole or into the new oil filter?
Was the fuel petcock turned off? I had a major problem with a previous bike hydrolocking when I left the gas on.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #3 of 34 (permalink) Old 05-30-2011, 09:22 PM Thread Starter
mpeace's Avatar
I put in 3.5 quarts,it was up to the full line,I drained it from the bottom center drain plug,no chance nothing fell in,my petcock is always on,but I drained the oil lastnight and refilled with more new oil and it was trying to turn a hair then it would stop,but now it want do anything.
mpeace is offline
post #4 of 34 (permalink) Old 05-30-2011, 10:14 PM
If you always drain the oil from the bottom center plug instead of the left side, maybe the screen is blocked with debris and you don`t know it.
post #5 of 34 (permalink) Old 05-30-2011, 10:20 PM Thread Starter
mpeace's Avatar
well I've only had the bike 3months and never really ran it,and only changed the oil twice.If the screen is blocked would that lock it down?
I never heard a sound in this motor until I changed the oil.
I have all the plugs out and still can't get it to do right.
mpeace is offline
post #6 of 34 (permalink) Old 05-30-2011, 10:25 PM
electrum's Avatar
the oil sight glass is on the left and the oil filler is on the left... you did put the oil in on the left and not on the right?, because the right is the coolant sight glass and filler.
96 Vulcan 750
electrum is offline
post #7 of 34 (permalink) Old 05-30-2011, 10:27 PM
If the screen is blocked it could could prevent oil from getting to the oil pump intake I believe. That could seize the engine if it ran too long without any oil pressure.
post #8 of 34 (permalink) Old 05-30-2011, 10:28 PM Thread Starter
mpeace's Avatar
Lol,yea I put the oil in the right place.
mpeace is offline
post #9 of 34 (permalink) Old 05-30-2011, 10:29 PM
bama750's Avatar
3.5 quarts sounds a little low my manual calls for 4.2 quarts when you change both the oil and the filter,
bama750 is offline
post #10 of 34 (permalink) Old 05-30-2011, 10:31 PM
bama750's Avatar
the manuall also states that the bike shoud be on the center stand and the oil level should come to the around the half way poing of the glass
bama750 is offline
