Oil Pump Chain Guide - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 05-30-2011, 03:00 PM Thread Starter
Roach's Avatar
I noticed in the service manual that there is an oil pump chain guide added on the later models.
Does anyone know if this can be installed on the earlier models that did not come with one? Is there an advantage to doing that?
I checked the parts number of the chain for the newer and later models (it was introduced in '86) and it's the same chain. I figure the guide might just work on the older case?
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
