can you help someone who is not very machanical fix is bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-23-2011, 04:08 PM Thread Starter
Hi everyone,
i was riding my bike all seems well when i changed up a gear and the bike jumped out of gear ?.
now when i start engine in nutral engine sounds fine but when i put it into gear any gear theres a sound coming from the back wheel like the gears slipping nocking and banging ?.
i can move the back wheel by hand freely when in gear but does not move under its own power.
please any pics or info and suggestions
gordon.
gordon is offline
post #2 of 5 (permalink) Old 05-23-2011, 04:20 PM
Originally Posted by gordon View Post
Hi everyone,
gordon.
Sounds like rear splines slipping. Read Fergy's procedure on the spline lube here. His instructions are so detailed, it may take longer to read it than to do the job. At any rate, pull the wheel as instructed and LOOK AT THE SPLINES.
Tell a little about yourself too!
VoIPDoc is offline
post #3 of 5 (permalink) Old 05-23-2011, 04:44 PM Thread Starter
thank you very much voip doc,
i will check this out
gordon is offline
post #4 of 5 (permalink) Old 05-23-2011, 05:19 PM
clock152's Avatar
sounds like you blew the final drive! Ouch!..if your realy realy lucky it is just the drive shaft. here is the link to the spline lube.
https://www.vn750.com/forum/showthread.php?t=17274
clock152 is offline
post #5 of 5 (permalink) Old 05-23-2011, 05:35 PM Thread Starter
cheers clock152,
fingers crossed i will soon find out at weekend
gordon is offline
