Iridium spark plug gap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-20-2011, 01:29 PM Thread Starter
Be True, Be Safe!!!
cheeser's Avatar
Thought I read it somewhere but can not find it. Do the Iridium plug come pre gapped or do you gap them. If so what to. I will continue to search but I bet posting this is faster. Thanks
Found it. Pre gapped.
Purchased 5/2010 w/7100 mi. mi
R/R relocate
Spline lube 05/10
After-market Mirrors
Iridium plugs
AGM MF Battery
Tank Bib Courtesy of Achaundy
Saddle Bags
Wolo Bad Boy Air horn
Protac driver backrest
Ccspiner Driver Floor Boards
Pending
Highway Pegs
Luggage rack.
cheeser is offline
post #2 of 5 (permalink) Old 05-20-2011, 03:45 PM
baldy's Avatar
You should still check the gap. It could have been changed if the box was dropped or rough handling in shipping. I have always checked the gap and would say 50% of the time the gap is off.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 5 (permalink) Old 05-20-2011, 03:58 PM
JM2001's Avatar
Check the gap. Two of mine were way off. .032-.034 works good. Be careful of the center electrode if you have to re-gap them.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 05-20-2011, 05:36 PM
HAWK
Ccspinner's Avatar
Be very careful on checking the gap on Iuridum, The tip is very sensitive and you can damage the plug.
All our factory plugs for Toyota state right on them "Do not gap"
The coting on the plug is so thin that you can scratch it and cause a thin spot which will result in premature plug failure.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 5 (permalink) Old 05-20-2011, 08:18 PM
cglennon's Avatar
They are suppose to come preset at .035" from the factory. Take the advise above; verify and install the ones that are and return the ones are not.
p.s. Mine were all properly factory set.
Chris Glennon - Portland, OR
cglennon is offline
