VN750 Engine Rebuild Videos - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 115 (permalink) Old 05-11-2011, 12:08 PM Thread Starter
Roach's Avatar
I'm tearing apart the engine on my VN750 with the intention of rebuilding it. I'm going to try and document the entire process in a series of YouTube videos.
Thanks to everyone for the tips so far, and please give me a shout if you have any more.
EDIT: I'm going to put all the videos in this first post to make them easier to find.
EDIT 2: I've also created a YouTube Playlist with all the videos
1985 Kawasaki Vulcan Engine Rebuilt Playlist
EDIT 3: I've been asked to note that the procedures in the videos are applicable to all model years from 1985 to 2006 for the Vulcan 700/750.
EDIT 4: Here is a crude spreadsheet with the cost
1985 Kawasaki Vulcan Engine Rebuild
Pt.1 - Removing & Disassembling Heads
Pt.2 - Removing Clutch, Starter Gear, Right Balancer, Right Cam Chains & Sprockets, Rear Cylinder, Stator & Cover
Pt.3 - Removing & Cleaning Valves, Removing HLA oil filter, Cleaning Heads
Pt.4 - Removing Flywheel, Left Balancer, Left Cam Chains & Sprockets, Front Cylinder
Pt.5 - Removing Final Drive, Damper Cam, External Shift Mechanism Cover, Oil Filter Plate
Pt.6 - Removing Pistons, Engine Case Bolts, Splitting Engine Case, Removing Crank Shaft, Transmission, Oil lines,
Pt.7 - Removing Water Pump Shaft, Water Pump Mechanical Seal, Oil Pump Sprocket & Chain, Balancer Shaft, Oil Pump, Left Side Oil Pipe, Oil Pressure Relief Valve, Oil PAssage Cover, Shift Drum, Shift Mechanism, Tie Rod & Shaft
Pt.8 - Bleeding HLAs, Checking Tolerances on Cam Shafts & Cam Shaft Covers
Pt.9 - Checking Tolerance on Heads, Cam Shafts, Cam Chains, HLA Leak Down, Valves, Valve Guides, Valve Seats
Pt.10 - Checking Tolerances on Valve Springs, Cylinders, Pistons, Piston Rings
Pt.11 - Checking Tolerances on Clutch Plates, De-glazing Clutch Plates, Checking Tolerances on Oil Pump
Pt.12 - Checking Tolerances on Crankshaft, Transmission, Honing Cylinders
Pt.13 - Lapping Valves
Pt.14 - Drilling Clutch Hub (Fix Coffee Grinder Noise), Installing Valves
Pt.15 - Installing HLAs, Rocker Arms & Springs
Pt.16 - Installing Oil Pump, Balancer Shaft, Oil Pump Chain & Sprocket, Oil Passage Cover, Oil Relief Valve, Oil Lines
Pt.17 - Installing Internal Shift Mechanism (Tie Rod, Shift Shaft, Shift Arm), Oil Pump Chain Guide, Oil Return Line, Water Pump Mechanical Seal, Water Pump Impeller & Shaft.
Pt.18 - Installing Shift Drum, Gear Position Lever, External Shift Mechanism Cover, Transmission
Pt.19 - Install Crankshaft, Combining Crank Case Halves, Oil Filter Plate, Starter Idler Gear, Right Side Balancer
Pt.20 - Install Left Side Balancer, Flywheel, Pistons,
Pt.21 - Install Cylinders, Cam Chains, Cam Chain Guides
Pt.22 - Install Heads and Spark Plug Retainers
Pt.23 - Installing Cam Shafts, Setting Cam Chain Timing, Installing Cam Cap, Cam Chain Tensioners, and Cam Shaft Cover
Pt.24 - Installing Flywheel, Primary Gear, Pick up coil mod, Shift Shaft Oil Seal, Left Side Engine Cover, Pick Up Coil Gap, External Oil Lines, Oil Pressure Switch
Pt.25 - Installing Clutch, Right Side Engine Cover, Clutch Cover
Pt.26 - Installing the Exhaust manifolds, Oil Drain Plugs, Carburetors, Starter motor, Final Drive Gearbox. Mounting the engine and starting the bike.
ihlebek likes this.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #2 of 115 (permalink) Old 05-11-2011, 12:31 PM
This is great. I'm anticipating the finished set of videos.
vulcanpower is offline
post #3 of 115 (permalink) Old 05-13-2011, 11:50 AM Thread Starter
Roach's Avatar
Edit
Whoops, something went wrong with part 2.
I'll try to re-upload it tonight
Street
Dirt
Roach is offline
post #4 of 115 (permalink) Old 05-13-2011, 04:09 PM
Bat
Bat
Bat's Avatar
There is nothing like seeing the job done firsthand, just being a fly on the wall and watching a masterful mechanic take things apart correctly and with explanations. Thanks for a great job on part 1, and I'm anxiously anticipating part 2!
Bat is offline
post #5 of 115 (permalink) Old 05-13-2011, 04:12 PM Thread Starter
Roach's Avatar
masterful mechanic
Hahahaha
Street
Dirt
Roach is offline
post #6 of 115 (permalink) Old 05-13-2011, 04:25 PM
cool man
qweesy is offline
post #7 of 115 (permalink) Old 05-13-2011, 04:43 PM
flitecontrol's Avatar
You must be a master mechanic, my hands never moved that fast removing stuff!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 115 (permalink) Old 05-13-2011, 04:53 PM
KidChaos's Avatar
very cool. thanks for doing this
KidChaos is offline
post #9 of 115 (permalink) Old 05-13-2011, 08:27 PM
wolflrv's Avatar
Awesome job! I'm working through the same process atm...taking down the motor completely for restoration. This is of great help!! Thx for taking the time!!
New rider/mechanic of '85 VN700 Vulcan. (25k miles)
Link to bike restoration blog:
http://trailofthewolf.blogspot.com/s...%20Restoration
wolflrv is offline
post #10 of 115 (permalink) Old 05-14-2011, 04:45 AM
Nice tear down. I have a comment tho, when you take the cams out would it be better to take out the ACCT's first? That way it takes tension off of the cams when you pull the plates off. I noticed that the cams were at an angle from the heads when you took off the cam plates from the tension on the chains. I believe it would also make it a little easier to get the cam plates off of the cams without the tension on the chain.
also are you going to replace the HLA's? If not does it matter which hole they go back in? I know on a multiple cylinder setup, I always put the valve train parts in order so that I can put them all back in the same order so they will wear the same. Especially a cam and lifters in a V-8 engine.
Again awesome job, I'm not telling you what to do of course, just a few comments.
RakerBill is offline
