VN750 Engine Rebuild Videos - Page 11 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #101 of 115 (permalink) Old 03-13-2014, 06:07 PM Thread Starter
Roach's Avatar
Hey Boys,
Yeah I make it on here every once and a while. Maybe more now that it's warming up.
There is a playlist.
I also have a crude cost spreadsheet, but it doesn't cover every item and you might need different parts than I did.
Rebuild Cost Spreadsheet
^I'll add this the the original post.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #102 of 115 (permalink) Old 03-13-2014, 06:35 PM
Originally Posted by Roach View Post
Hey Boys,
How ya been ? Get in many miles in last season ?
Any plan's/trip's for this season ? (Gotta keep the bearings rolling LOL)
post #103 of 115 (permalink) Old 03-13-2014, 07:26 PM
Crowley
crowley1027's Avatar
Hey Roach. I'm thinking of blowing chunks (of money) on a used 700 and building it up brand new. What do you think the cost will be? I see a few thousand maybe... It'd be nice to get some opinions on rough estimate of cost. I'm talking valves, valve assembly, Pistons, crank, cams, chains, Conn rods, bearings, everything.
That way, whenever my motor craps out I'll just plop the new guy in.
crowley1027 is offline
post #104 of 115 (permalink) Old 03-13-2014, 07:29 PM
Firefighter 85 has a 700 for sale.Hello Roach how ya been?
post #105 of 115 (permalink) Old 03-13-2014, 08:29 PM
But Firefighter's frame is MINE.....lol
post #106 of 115 (permalink) Old 03-14-2014, 03:47 PM Thread Starter
Roach's Avatar
I've been good.
I didn't ride as much as I would have liked to last summer, as I bought a house in June and that kept me pretty busy. I also had shoulder surgery in August so that cut the season short.
I did manage to drive to to and from work a bit.
I did a couple short trips with the girlfriend (1-2hr long). I think I might try and get her a bike this summer (Maybe do some more videos?).
I put a FuzeBlock fuse box on the bike for powering accessories. I also added heated grips and a windshield.
Unfortunately I went to take the windshield off in October and it cracked right in the middle at the bottom. It was a National Plexistar 2, and since it is an acrylic model National doesn't provide warranty. It was only 6 months old.
Another bummer is the bike seems to have leaked oil from the case somewhere this fall. I haven't had time to pinpoint the exact location, I'm just hoping it's not at the crankcase split face. If it is, I might just try running non synthetic. I really don't want to have to split that case again so soon.
I'm working on putting a basement suite in my house right now, so I probably won't make it out to the garage until that's finished.
Nadan, as far as the costs to do a complete rebuild I'm really not sure. I'd probably make an account on a site like BikeBandit.com and add all the parts you think you need to a cart and see how it adds up. But you won't really know what needs replacing until you open it up.
Street
Dirt
Roach is offline
post #107 of 115 (permalink) Old 05-19-2015, 12:05 AM
Crowley
Successfully rebuilt my engine with (a lot of) help from these videos.
Note to anyone (and this should be put somewhere important) timing the engine during rebuild:
The end of one video concludes with the completion of one cylinder's timing, and the next video begins the other side timing.
He doesn't explain how to turn the engine after rear timing....
Do not rotate the engine the small portion of the way. You must rotate the engine around three hundred something degrees.
I made the mistake of timing rear cylinder on compression, rotating engine forward a small bit, and timing front on compression. They both ended up being on the same stroke, and luckily I caught it before it went together.
You must rotate the engine so after timing the rear cylinder on compression, rotate engine until rear cylinder is on exhaust stroke, set front to top dead, and time for compression stroke.
post #108 of 115 (permalink) Old 05-16-2016, 05:35 AM
that's really so amazing i am working on the same project surely it will hep me .. thanks man for posting this
hopjis is offline
post #109 of 115 (permalink) Old 07-12-2018, 11:02 PM
NorcalSpoK
I have been completing the same basic processs. Tear down and rebuild the engine on my 04 Vn 750 because I had to get the rear cylinder head re-machined due to a bad spark plug hole. I am almost done (?) but it seems that the engine runs a bit rough and there is an antifreeze leak apparently from the radiator just above the bottom of the fan and there is still an apparent oil leak possibly at the starter gaskets. I just replaced the oil pressure sensor /switch but there is still the oil leak and antifreeze leak. What is the best way to deal with the antifreeze leak? Also my clutch does not seem to be firm and I have been trying to adjust the clutch cable but not making much progress. Any suggestions?
Thanks an$ God bless
Spock070915 is offline
post #110 of 115 (permalink) Old 01-12-2020, 11:20 PM
Hey Boys,
Roach, want to say a huge Thank you for the videos and the spreadsheet! I just finished my rebuild - had to split the case to replace shifter rod link that broke off at the welding (what a lazy design!).
Now, I ran into an issue with right-hand cover (clutch cover) tightening the starter idling gear. When the cover is on and screws are in but not tight, the engine cranks fine, but whet tightened, it's hard to crank the engine clockwise (as the starter would). I ordered a new gasket just to make sure the one I had wasn't too thin, but I may have put a little too much grease on the both ends of that gear. However, I am not 100% sure that's the culprit.
Have you dealt with such tight crank after you put the right cover on?
Also, did your right balancer gear had a bit of play between the balancer and the beveled washer?
Thanks in again!
Edit: just rewatched your video, and I can see the washer is on the outside of the gear. I'll check it on Wed and hopefully that'll fix it.
oddozoo is offline
