Not starting after sitting for a while... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 05-05-2011, 05:54 PM Thread Starter
CBH
CBH's Avatar
So I got it running after the winter storage, and it ran like a dream. Then it sat for about a week as it was cold here in the Great White North and then it would not start again. I did the same steps as previous and got it going...ran beauty eh...so I'm wondering if it just needs to be started and ran more or if there might be a problem brewing that I need to be aware of. Any suggestions?
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new throttle pull back cable
new spark plugs
New Bridgestone on the back
New Fluids all around
SeaFoam in the tank
CBH is offline
post #2 of 2 (permalink) Old 05-05-2011, 06:11 PM
JM2001's Avatar
I would first check the plugs for moisture, gap, and possibly replacement. I would then drain the fuel bowls and remove the drain screws. I would then squirt carb cleaner ( alot ) into the drain hole to flush out the floats. It should start. I would then add 1/4 can of SeaFoam to a fresh tank of gas and run the bike fairly hard to clean out the jets.
By the way, you live in a beautiful part of the Country. Went thru there on my way to Lake Superior.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
