Is there any help for a stuck HLA?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 05-05-2011, 05:11 PM Thread Starter
I have an HLA that is clattering in my engine. It was really bad yesterday. I had my bike running, and at idle it was pretty loud and it was clattering intermittenly.
I recently changed my oil, and I put in Castrol 20W50, and it's still in the lower 50 degree range outside.
Could the oil be a little too heavy for the cooler weather?
Could it have an affect on the HLA's?
I checked both ACCT's and they are both working good. The noise don't start till around 2,000 RPM's and usually after it's warmed up a bit.
I added some Seafoam to the oil last night and went for a short ride to see if it helped any.
Is there anything I can do to help free it up? I might have to do another engine pull and look at them.
The noise is coming from the front cylinder, but the weird thing is that under acceleration it goes away, it seems to make the most noise under cruising conditions ie: with no load on the engine.
Any ideas from the brilliant mechanics out there? Thanks all.
RakerBill is offline
post #2 of 21 (permalink) Old 05-05-2011, 08:46 PM
Calif Rider
weh44att's Avatar
How did you check the ACCT's, you still could have a very weak spring or a busted one? Did you take them out and check the front one. You have a large cap just above the ACCT, remove, there is a spring in there that also puts tention on the upper chains. See if it is broken this could also give you a loud chain slap.
You said that you had the engine out, what was done after it was removed?
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 21 (permalink) Old 05-05-2011, 10:24 PM
Be True, Be Safe!!!
cheeser's Avatar
HLA ???? Advise the dummy please.
Purchased 5/2010 w/7100 mi. mi
R/R relocate
Spline lube 05/10
After-market Mirrors
Iridium plugs
AGM MF Battery
Tank Bib Courtesy of Achaundy
Saddle Bags
Wolo Bad Boy Air horn
Protac driver backrest
Ccspiner Driver Floor Boards
Pending
Highway Pegs
Luggage rack.
cheeser is offline
post #4 of 21 (permalink) Old 05-05-2011, 10:27 PM
Calif Rider
weh44att's Avatar
What he is saying I think is Hydrolic, lifter, assembly. that is what I come up with.
2004 25,500 miles
Headlight modulator
R+R relocation
Fused Stator
Ride-on in tires
iridium plugs
weh44att is offline
post #5 of 21 (permalink) Old 05-05-2011, 10:33 PM
Concert connoisseur
wib714's Avatar
when my acct spring broke I was 40 miles from home, at idle and low cruising speeds it was clacking like hell, if I kept the rpm's up it was fine so I revved it the whole way home, put in a new spring and it was gone. for less than 6 bucks and a quick trip to the hardware store and 10 minutes you can convert it like I did in my signature line and see if it fixes it, you can always switch it back to an acct later if you want but shouldnt need to. I would try that first!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 21 (permalink) Old 05-06-2011, 04:55 AM Thread Starter
HLA is the Hydraulic Lash Adjuster under the rocker arms that keeps the rocker arms in contact with the camshaft lobes.
I manually checked both ACCT's with a screwdriver with the engine running. I turned them CCW slowly until the chain started rattling, then released the screwdriver, and the chain noise went away. I then turned the screws slightly CW to make sure there was sufficient tension on the chains.
I checked both springs under the caps above the tensioners, and both were good with tension on them.
I checked the timing chain tension when I had the engine out and both chains were tight.
I am almost positive the noise is coming from a lash adjuster as the noise is intermittent.
At idle the engine makes absolutely no noise at all. You rev it up to 1,000 RPM's, and still no noise. It don't make any noise until roughly 1,800 RPM's and the noise is the worse at cruising speed.
I will check the springs under the caps again, and I am going to go get some flat washers to put between the caps and the springs to see if that helps any.
I had the engine out to do some carb work, and to replace all of the O-Rings and water & fuel lines.
post #7 of 21 (permalink) Old 05-06-2011, 11:45 AM
Calif Rider
weh44att's Avatar
When I checked the spring behind the large caps they measured at a little over 1 and 1/2in long. Right for wrong I stretch them to about 2 inches long, because I was having a little noise in the top end. They do not seem to be made of hard tempered steel.
2004 25,500 miles
Headlight modulator
R+R relocation
Fused Stator
Ride-on in tires
iridium plugs
weh44att is offline
post #8 of 21 (permalink) Old 05-06-2011, 04:18 PM Thread Starter
I'm going to take the springs with me today, and get some new ones that are a little longer with a little more tension, and see if that helps any, and will post the results.
I'm hoping that I can get a sound recording at various RPM's so that everyone can hear what I'm hearing in the engine.
post #9 of 21 (permalink) Old 05-07-2011, 02:59 AM Thread Starter
I added 2 flat washers behind the springs tonight, and they had no affect on the noise at all. I checked the ACCT's again, and they are both tight.
If I tighten them much past snug, it will actually pull the engine down, and I can hear the chains against the guides.
I changed the oil and it didn't help either.
The noise is coming from the front cylinder.
So I guess it's time to pull the engine AGAIN.
Anyone want to buy a parts bike?
post #10 of 21 (permalink) Old 05-07-2011, 10:05 AM
try some Lucas OIl treatment,before you pull the engine,it may help,the sound you describe sounds like a collapsed lifter,or it may be stuck in it's bore,but usually they are noisiest at idle ,when oil pressure is lowest.
I have personally used Lucas,oil treatment with good results,you will have to drain some of your oil and add the additive,then run your engine until it runs N.O.T. and then try letting it have time to pump up the bad HLA ,if the noise doesn't go away then pull the engine.
I am in no way affiliated with Lucas Additives I am just convinced through my own experiences they make good stuff,It's worth a try.
