Maybe a STUPID QUES. But?!? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 04-21-2011, 05:02 PM Thread Starter
ryanmitchy's Avatar
Theres a plastic bottle thing and i have no idea what its for. It has full and low on it and as a newb i figured it was for the oil
ryanmitchy is offline
post #2 of 16 (permalink) Old 04-21-2011, 05:10 PM
JM2001's Avatar
For antifreeze. We have a water cooled engine. Needs a 50/50 mixture for aluminum engines.
Welcome to the Forum
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 16 (permalink) Old 04-21-2011, 05:11 PM
Git-R-Done!
AZ Kev's Avatar
Are you talking about the reservoir for antifreeze? If it is on the right side, and black, chances are that's what it is.
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #4 of 16 (permalink) Old 04-21-2011, 05:21 PM
Concert connoisseur
wib714's Avatar
not a stupid question if you didnt know. could have been screwed if you filled it with oil without asking!
Welcome to the forum!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 16 (permalink) Old 04-21-2011, 05:36 PM
Mine was chrome....
Which reminds me, I still have the stock black one if anyone is looking for one.
post #6 of 16 (permalink) Old 04-21-2011, 05:50 PM Thread Starter
ryanmitchy's Avatar
haha., i dont know if i actually did this but i think i might have put some oil in before. I could be wrong but i damn sure i hope im wrong. If i did it would of been like last summer and ive driven it for a whole summer so im hoping i didnt and if i did it didnt screw anything up.
Next Quest. What kind of anti freeze should i add? is there a motorcycle kind or just reg anti freeze works?
post #7 of 16 (permalink) Old 04-21-2011, 05:57 PM
JM2001's Avatar
Regular antifreeze sold at auto parts places and Walmart are fine. Just read the label. It must say " formulated for use in aluminum engines " or something like that. I hope you didn't add oil also.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 16 (permalink) Old 04-21-2011, 06:18 PM
Get a coolant tester and suck some liquid out of that overflow bottle.
Check it to see if there is oil in the coolant.
If there is, I would get a coolant system flush kit from an auto parts store to use after draining the old coolant.
Any antifreeze compatible with an aluminum engine should be fine.
The green colored coolant is easier to read the level in the coolant overflow bottle sight slot than the yellow stuff is.
post #9 of 16 (permalink) Old 04-21-2011, 06:22 PM
There is no such thing as a stupid question unless it isn't asked. If you did add oil to the tank, you can pull the tank off and clean it. There is a good chance that the oil never reached the coolant system because the hose is pretty long and it would take quite a bit to get to the cooling system. It's pretty easy to get to the hose to flush it if you have to.
RakerBill is offline
post #10 of 16 (permalink) Old 04-21-2011, 09:35 PM Thread Starter
ryanmitchy's Avatar
Im gonna get a tested and see if thats the case., im hoping i didnt and i think im 80% sure i didnt add oil to it but its worth the test. Thanks for the help
