Engine vibrations - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-18-2011, 01:33 AM Thread Starter
Question Engine vibrations
Had to have my shift shaft replaced. Took the engine out and took it to the dealer. they replaced the shaft and I put the engine back in. also added a set of vance and hines pipes. But once I got it running it has a vibration problem. Broke license plates and a gas tank mount. I thought at first that maybe it was the pipes but I don't think so. The dealership doesn't seem to have an idea. At about 2000 rpm it looks like the mirrors are about to come off. rpm increase it smooths out but will make my right foot go numb after a while. right side seems worse. motor mounts look ok and don't see anything touching that shouldn't be. I'm lost. any ideas out there.
camai is offline
post #2 of 6 (permalink) Old 04-18-2011, 08:44 AM
Concert connoisseur
wib714's Avatar
you sure you got all the rubber bushings reinstalled with the motor mounts?
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 6 (permalink) Old 04-18-2011, 11:05 AM
JM2001's Avatar
If you do have the rubber bushings installed I would check the motor mounts again. I believe the fronts may not be tight enough or possibly all of them. The bushings may not be seated properly. I still think it's the front mounts.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 6 (permalink) Old 04-19-2011, 02:40 AM Thread Starter
Thanks I'll check that again and more closely
camai is offline
post #5 of 6 (permalink) Old 04-19-2011, 12:03 PM
flitecontrol's Avatar
Depending on the age/condition of your rubber balance dampers, they may need replacing.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 6 (permalink) Old 04-19-2011, 12:31 PM
there is also they didn't line up the marks on the balancers properly,when they put the engine back together and to me this sounds like the classic symptoms of this since it started after they had it apart,the bushings are a possibility too if they didn't replace them,which there is no excuse for if they had it torn down.
Either way
they need to take it apart and check it out since they did the work and they shouldn't have let you have it back and charged you for it if it wasn't right.
