tips and suggestions for replacing exhaust gaskets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-14-2011, 06:52 PM Thread Starter
Wareagle1970
carolesteven's Avatar
Got my OEM Kaw. gaskets in today and was wondering if anyone had any tips or tricks in installing. Know the flat side of the gasket goes towards the manifold, while the slightly tapered side goes towards the manifold pipe.
Anything??? This is my latest endeavor to eliminate the deceleration popping...
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 13 (permalink) Old 04-14-2011, 07:08 PM
First off... Everyone I know uses Harley gaskets...Perhaps someone has the part number handy?
I always put a bit of bearing grease on the gasket to help hold it in place ... It burns off after a few hard miles.
But yeah, serious about the HD gaskets..
Edit... HD part # 17048-98 ....knew I had it somewhere....
post #3 of 13 (permalink) Old 04-14-2011, 10:46 PM Thread Starter
Wareagle1970
already ordered and have the Kaw OEM gaskets...
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 13 (permalink) Old 04-15-2011, 05:41 PM
i used the kawi ones aswell what I do is put a film of copper sealant in the head port before i stick the gasket in the raised pyramid section faces out towards your exhaust pipe so when you bolt it down it will crush the gasket against the pipe to fill in any deformity
qweesy is offline
post #5 of 13 (permalink) Old 04-15-2011, 06:13 PM
Well, I had both in my Vulcan.. A kawasaki gasket with the Harley one on top of it. Never leaked.... Just needed the extra 0.10 of an inch to clear the highway bar I made.
But yeah, if you do have a leak the Harley ones are better.
post #6 of 13 (permalink) Old 04-15-2011, 07:17 PM
Ceal's Avatar
are the exhaust gaskets just round ring-like gaskets? Sorry, I'm used to exhaust gaskets on cars, I had a completely different image in my head, so I just want to make sure I don't order something else.
Ceal is offline
post #7 of 13 (permalink) Old 04-15-2011, 07:58 PM
peerless's Avatar
The only advice I can give from experience is to spray the nuts/bolts with PB Blaster and go slow when removing them. If you meet a lot of resistance, use the PB Blaster more and work the nut back and forth until it is removed.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
post #8 of 13 (permalink) Old 04-15-2011, 10:32 PM
Like a little copper donut.
post #9 of 13 (permalink) Old 04-16-2011, 02:26 AM
Ceal's Avatar
lol nicely put! No wonder they are far less expensive than what I expected
Ceal is offline
post #10 of 13 (permalink) Old 04-16-2011, 09:59 PM
Heading to the DARKSIDE!
BRET H's Avatar
2 X on what Knifemaker said....the harley gaskets are much better....I had trouble with seating up the Kaw gaskets on my V&H Cruzers......grease holds them just fine. It usually all burns off during the first bike warm up after install.
BRET H is offline
