Know your tired of ACCT questions but.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-06-2011, 11:54 AM Thread Starter
2002 vn 750
I know everyone is tired of ACCT questions but I can't seem to find this on the forum anymore. Guess I don't know how to search well enough. Question is, I'm replacing my ACCT's with new ACCT's this weekend. Thought I read that you have to have the piston TDC. Is this true with new ones that are suppose to be prewound until you install them. Also I thought I read how to find TDC but again I can't find it. Something about taking the side cover off and there are markings inside to align to. Thanks in advance.
vila is offline
post #2 of 11 (permalink) Old 04-06-2011, 12:32 PM
Just take the old ones out and put the new ones in......just don't turn the engine with the ACCT's out....
dariv is offline
post #3 of 11 (permalink) Old 04-06-2011, 01:30 PM Thread Starter
2002 vn 750
That's what I was hoping for! Should only take a few minutes to do the job then once I get to it!
vila is offline
post #4 of 11 (permalink) Old 04-06-2011, 08:08 PM
Concert connoisseur
wib714's Avatar
x2, 10 minute job on each side if that. you will need a small screwdriver to twist the spring on install till the housing lays flush on the engine, tighten the nuts and then release the spring and install the capscrew!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 11 (permalink) Old 04-06-2011, 08:43 PM
Be gentle with the cap screw. The threads in the acct case can be ruined easily.
post #6 of 11 (permalink) Old 04-06-2011, 09:22 PM
Ceal's Avatar
Where did you get the new ACCTs? How much did you pay for them?
Ceal is offline
post #7 of 11 (permalink) Old 04-06-2011, 10:11 PM
OEM Parts $58.60 each, shipping $13.50 in USA:
http://www.indyoem.com/fiche_section...1991&fveh=9040
post #8 of 11 (permalink) Old 04-06-2011, 10:20 PM
Patriot Guard Rider
The DEUCE's Avatar
Here's the ACCT rebuild instructions. I just ordered their MCCT's instead.
http://www.tocmanufacturing.com/ACCT...structions.htm
VN750 #9300 & VROC #33453
The DEUCE is offline
post #9 of 11 (permalink) Old 04-06-2011, 11:18 PM
That is the way to go, with the mcct's. Some times even the new acct's will not last long.
post #10 of 11 (permalink) Old 04-06-2011, 11:20 PM
Patriot Guard Rider
The DEUCE's Avatar
x2
