Crazy Acct find - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-03-2011, 06:39 PM Thread Starter
Crazy Acct find
I finally was getting around to making Mcct's out of the Acct's using the ideas i've seen on here which look awesome. I decided before I start to see if I could get the front acct to tighten any while it was running. Lo and behold when I loosened the bolt in the end just a smidge the clacking stopped. I tried grinding off the end of the bolt a little and put it back in but when I tightened it the clacking came back.I backed off just a little bit and it went away again! Rode about 50 miles today and it's the first time since I rebuilt the engine that i've had a quiet ride. Just thought I would throw this out there in case it might help someone else.
'93 VN750 purchased July 2010 50,000 miles
Rebuilt engine
AGM battery
fred111 is offline
post #2 of 4 (permalink) Old 04-10-2011, 09:41 PM
Patriot Guard Rider
The DEUCE's Avatar
Did this resolve your Cam Chain tick?
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 4 (permalink) Old 04-11-2011, 11:50 AM
Did you loosen the bolt while the engine was running? Surely you couldn't leave it loose or it would vibrate out after a short time. Interested in knowing exactly how you proceeded. Make one wonder if using a longer bolt with a lock nut on that would allow you to back it off and tighten the nut would do the trick.
keltec is offline
post #4 of 4 (permalink) Old 04-11-2011, 09:35 PM
I've got about 400 miles on my engine since I rebuilt the top end. The clacking has been driving me nuts. Was pretty much leaning toward MCCTs, but you've given me some hope. Gotta play with it some tomorrow, see if I can duplicate.
1998 VN750
37,100 miles
Spline Lubed
2 Previous Owners
Rebuilt Top End at 33K
banjojeffery is offline
