Seafoam question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 15 (permalink) Old 04-03-2011, 06:17 PM Thread Starter
1985 VN-700
L2fish's Avatar
Seafoam question
I seafoamed my gas today. I put 2 ounces in the 1/2 full tank. The bike is smoking like a hippie. Is that normal?
L2fish is offline
post #2 of 15 (permalink) Old 04-03-2011, 06:26 PM
Joshua's Avatar
The first time I ran it through my '83 Nighthawk 750 it did that. May want to hear from some of the others here first, but I think it's fairly normal. The Nighthawk did it A LOT but after it cleared it ran much better.
1985 Vulcan 700 (VN700A1) - 18,960 miles - bought for $600 - was told it only needed carb idle screws and fuel lines to run correctly - it used to start
1983 Honda Nighthawk 750 (CB750SC) - 30,000 miles - 95% fully restored
Joshua is offline
post #3 of 15 (permalink) Old 04-03-2011, 07:12 PM
Patriot Guard Rider
The DEUCE's Avatar
Sounds normal to me. I put the whole can in a full tank even though it says it's good for a minimum of 8 gallons. I use Seafoam on my truck through the brake booster and she smokes like a chimeney for 15 minutes.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 15 (permalink) Old 04-03-2011, 07:49 PM
scuba's Avatar
I used seafoam in a fresh tank of gas. Smoked a little at first, but what do you expect it is in the process of kicking butt. totally normal.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #5 of 15 (permalink) Old 04-04-2011, 11:06 PM
techdif's Avatar
I put half can to a full tank and no smoke at all
Look where your going not where you've been!
06 VN750
gutted mufflers
E3s
soft bags
windscreen
techdif is offline
post #6 of 15 (permalink) Old 04-05-2011, 02:11 AM
99vulcan750's Avatar
same here!
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #7 of 15 (permalink) Old 04-05-2011, 10:07 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #8 of 15 (permalink) Old 04-05-2011, 01:48 PM
Ceal's Avatar
Mine smoked as well. It will stop it with the next fill up.
Ceal is offline
post #9 of 15 (permalink) Old 04-05-2011, 02:21 PM
baldy's Avatar
Seafoam is an additive that cleans and not as flammable as gas so that is where the smoke is coming from when using a higher dosage. It also depends on if it is fresh gas as apposed to some that has sat for a while. The other stuff that I use regularly K-100mg doesn't smoke but you can feel a slight difference in how it runs. That has a bit more flammability then seafoam. One thing about using a lot of additives.....You should check your plugs periodically to make sure they are burning good. Sometimes over use of an additive can put build up on them and reduce the burn/spark.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #10 of 15 (permalink) Old 04-05-2011, 10:09 PM
I used seafoam twice on my last bike (500 vulcan). The previous owner did not care for her at all as the leather seats where torn, chipped/peeling paint, and rust on the engine/chrome pieces... So needless to say the inside was no different, when I ran the seafoam I completely clogged up the fuel filter (rusty tank) and must have loosened crap into the carbs as she would bog down under full throttle... I solved the problem by running carb cleaner through the fuel line (should have cleaned the carb) as I had never torn down a carb b4 and was rather bashful... Now that I know how simple it is (have seen step by step guides) I'd have no problem. But boy am I glad to have my newer 04 750 vulcan now! She runs like a dream. As for seafoam, that stuff works great, definately does it's job! Just in my case when used on an older bike it got me into some trouble though saved me from the same problem down the line!
When Chuck Norris heard news of the VN 750, he decided to become one!
2004 750 Vulcan
-Marbled
-AGM M/F Battery
-Corbin seat
Unclemoney is offline
