Coolant leak?!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-29-2011, 07:28 PM Thread Starter
Coolant leak?!!
There's a small coolant leak in my 86 750 but I don't know where it's coming from ... somewhere from in the center of the bike. Does anyone know any common problem spots for this type of thing???
vulcanpower is offline
post #2 of 3 (permalink) Old 03-30-2011, 08:48 PM
Bronson's Avatar
Hi: Central coolant leaks can originate as low as the front cylinder base gasket. Often the leak will be higher up and run down the engine into the area between the cylinders. Common areas to check are the metal coolant tube at the top of the front cylinder. Also take off the gas tank and look over the hoses to the front and rear cylinders, the thermostat area under the gas tank, and up to the radiator neck.
The head gasket can also leak.
Is there coolant pooling between the cylinders? Is there coolant under the bike when you stop? Trace it to the highest point you can.
Check the coolant for discoloration. Also check the oil for level (if coolant is leaking into the oil the level will rise, and the oil will look milky.) and color.
Hope you have an easy fix. Bronson
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #3 of 3 (permalink) Old 03-30-2011, 09:22 PM
^what bronson said plus the chrome coolant tube near the center (o-rings) and the weep hole on the bottom coming from the mechanical seal on the water pump,but as he stated start high up on the bike also check the coolant overflow tank for cracks and the hose coming to it from the thermostat housing.
