Motor part?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-01-2011, 07:50 PM Thread Starter
Motor part??
Hi Everyone, let me first appologize for this being my first post. I generally do introduce myself and try not to be one of those random posters before asking for help...but I'm in the middle of a stator redo and came across this washer laying on the garage floor and I'm not positive if it came out of the engine or other areas, but I do want to make sure before I start the rebuild. The size is about that of a nickel and it does slide over the shifter shaft perfectly, but I've tried looking around the OEM parts section of cheap cycle parts to see if I could identify its location, no luck. With the pic attached, I was hoping someone could identify it and explain where it goes. This only aggrevates my '06 VN750 w/ 6K miles which already needs a stator. Hopefully the summer will be long. Many thanks folks...and I wouldnt have attempted this w/o this site. Thanks, Rick
IndyVN is offline
post #2 of 12 (permalink) Old 03-01-2011, 08:28 PM
Concert connoisseur
wib714's Avatar
gonna look at my walkthrough and see if I remember anything like that, kinda looks like and exhaust gasket but if I remember right its quite a bit bigger than a nickel!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 12 (permalink) Old 03-01-2011, 08:32 PM
Concert connoisseur
wib714's Avatar
could be a washer to one of your motor mounts, does it fit over the long bolts that mount the engine?
And welcome to the group! just go back and introduce yourself in the new members area, you will get a ton of welcomes and great advice!!!!!!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 12 (permalink) Old 03-01-2011, 09:49 PM
flitecontrol's Avatar
Can't help with the washer, but get your stator rewound here: http://www.tpe-usa.com/
When he's done with it, it is beter than OEM, only costs around $65 plus shipping, and isn't a cheap Chinese stator like most everyone sells!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 12 (permalink) Old 03-01-2011, 10:19 PM
Cheman's Avatar
If I'm not mistaken, I think it goes on the shift shaft on the inside of the cover. I cannot get the cheapcycleparts diagrams to show up to find it. there should also be a circlip on there if I recommember.
Che
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
post #6 of 12 (permalink) Old 03-01-2011, 10:33 PM
1986vn750's Avatar
http://www.kawasakipartsnation.com/p...d/default.aspx maybe the washer form the shifter. Fill in the fields, and find the drawing for the gear change assembly. maybe? idk if you took that apart.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #7 of 12 (permalink) Old 03-01-2011, 10:36 PM
Cheman's Avatar
found it on ron ayes http://www.ronayers.com/Fiche/TypeID...ange_Mechanism part 92022 washer. They keep the shift shaft from moving in and out.
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
post #8 of 12 (permalink) Old 03-01-2011, 10:39 PM
1986vn750's Avatar
yup. i found part no. 92022
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #9 of 12 (permalink) Old 03-03-2011, 07:06 PM Thread Starter
Washer
Thanks Cheman, I was actually able to enlarge that enough to look at it w/o distorting the pic too much. I'm thinking it's the one that sits between the shift arm and the housing, because I didnt mess with anything past the circlip. When I pulled the shift arm off it must have still been stuck to it. The backside of the shift arm has a wear pattern that fits the washer almost perfect, so I'm pretty sure that's where it goes. Appreciate the inputs guys. Now its time to box the stator for shipping to TPE. By the way...anyone know if he accepts money orders??
IndyVN is offline
post #10 of 12 (permalink) Old 03-03-2011, 11:56 PM
Here`s TPE`s ebay link with payments info
http://cgi.ebay.com/ebaymotors/motor...Q5fAccessories
