Balancer and shaft alignment question? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 02-20-2011, 02:14 AM Thread Starter
If the balancer and shaft are not aligned correctly(dots not lined up).
Will it make noise as well as shake?
Or just shake?
Thanks.
ckrockets is offline
post #2 of 6 (permalink) Old 02-20-2011, 05:02 PM
I'm not sure if it would make any noise, but it will shake, and possibly cause engine damage.
RakerBill is offline
post #3 of 6 (permalink) Old 02-21-2011, 09:29 AM
Look for a small mark on the balancer. This should line up with a small arrow on the rotor. I use to have pics of it but I can't find it & The free online manual has too poor of pics to see it clearly. If I'm not mistaken the mark on the balancer is about a .25" line near the teeth. Good Luck.
P.S. It will shake like crazy if it's off.
post #4 of 6 (permalink) Old 03-28-2011, 03:12 PM
Mushu's Avatar
Send a message via MSN to Mushu
Balancer not aligned
Or just shake?
Thanks.
I guess it depends how off the alignment is, I have mine off by a few teeth and if vibrated not to bad but enough to blur all images in the mirrors. It got it aligned over the weekend and also replaced the balancer bushings... not that they where gone but certainly they were hardened and must likely would have needed replacement in a year or two. There are other posts where they report similar situations.
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #5 of 6 (permalink) Old 04-23-2011, 02:28 AM
I have a vibration/shaking problem. Does this balancer problem affect it while just sitting or is it only when moving?
camai is offline
post #6 of 6 (permalink) Old 04-23-2011, 01:27 PM
Since any engine vibration is a result of the engine parts rotating, not any driveline components or the wheels, I would say the engine will vibrate/shake just sitting still too.
