any ideas? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 02-15-2011, 06:01 PM Thread Starter
any ideas?
OK i got my carbs back in and everything hooked up. Bike starts and runs, but when i let off the throttle it backfires (some times) and dies. Starts back up no problem but same end result.
adwalker67 is offline
post #2 of 8 (permalink) Old 02-15-2011, 08:35 PM
Is the idle set at 1100 rpm? Use the the black knob down on the left side of carbs to adjust idle speed.
Were the fuel/air mixture screws under the cap seals turned out further. Probably need 2 1/2 to a max of 3 1/2 turns out to cut down or stop backfiring.
I`m not sure if complete elimination of backfiring is possible.
post #3 of 8 (permalink) Old 02-19-2011, 09:29 PM Thread Starter
i have messed with the idle screw but no help...also my tach is broke and dosnt read correctly.
post #4 of 8 (permalink) Old 02-20-2011, 12:42 AM
what did you do to your carbs when you had them out... sorry if I missed your post
post #5 of 8 (permalink) Old 02-20-2011, 09:27 AM Thread Starter
i had them completely taken apart and cleaned...
post #6 of 8 (permalink) Old 02-20-2011, 09:52 AM Thread Starter
and you should know my battery is crap
post #7 of 8 (permalink) Old 02-20-2011, 11:15 AM
whill it run when you hold the throttle open?
post #8 of 8 (permalink) Old 02-20-2011, 12:27 PM Thread Starter
ok i put a new battery on, adjusted the air/fuel screw and fixed my idle adj....the idle had come unscrewed...now it seems to idle fine at around a grand and no backfires. Seems to do fine with a lot of throttle and no choke as well. now on to the other bugs that i need gone to get her on the road.
2003 vn750...no mods yet
