clanking noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 02-15-2011, 05:00 PM Thread Starter
scuba's Avatar
clanking noise
I heard a clanking noise coming from the engine. It doesn't effect the way it rides or anything. The noise just comes and goes. I dont think it's a rod, maybe a sticky lift could cause this?
Any input is appreciated.
scuba is offline
post #2 of 14 (permalink) Old 02-15-2011, 05:05 PM
deleted
FlacoLove is offline
post #3 of 14 (permalink) Old 02-15-2011, 05:11 PM
Does it sound like a ticking noise from the left front of the engine, right rear, in the center, certain rpm, acceleration, deceleration? Have you checked your oil, water level?
master-paul is offline
post #4 of 14 (permalink) Old 02-15-2011, 05:24 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Do you primarily hear it when idling, just after start-up? Mine will do that every so often. I am thinking that mine is asking for the ACCT to be looked at. Mine goes away once I've ridden it for a few minnutes.
Chris and Shim is offline
post #5 of 14 (permalink) Old 02-15-2011, 05:29 PM Thread Starter
scuba's Avatar
I hear it by the carberator, right side. sounds like a nickel hitting metal sound. I only hear it when I am stopped and it's just idling. It doesn't get louder or softer same noise. Sometimes it happens sometimes it doesn't. I havent had the carbs cleaned out and dont have any information on the last owner what work he had done. I poured some seafoam gas treatment and noise went away for 2 months. Then it made the noise again.
scuba is offline
post #6 of 14 (permalink) Old 02-15-2011, 05:31 PM Thread Starter
scuba's Avatar
Just had the oil changed about 400 miles ago, all fluids are full. I changed the plugs and wires about 200 miles ago. Seems like when I give it full throttle it bogs a little. (struggles to accelerate fast)
scuba is offline
post #7 of 14 (permalink) Old 02-15-2011, 05:40 PM
It wouldn't hurt to pull the carbs off and give them a good cleaning and looking at, I can't think of any thing inside the carbs that would rattle sometimes and not other without not running(like a loose jet). I say pull, clean, inspect, and go from there. Also check you ACCT's for slack (grambo trick).
post #8 of 14 (permalink) Old 02-15-2011, 06:48 PM
flitecontrol's Avatar
I wouldn't pull the carbs if adding Sea Foam stopped it before. I'd add more Sea Foam first and see what happens.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 14 (permalink) Old 03-28-2011, 10:58 PM
i am having the same problems. the noises is coming from the right side of the engine. mine is 2002 model
fangyooo is offline
post #10 of 14 (permalink) Old 03-29-2011, 08:54 AM Thread Starter
scuba's Avatar
yep, that's where I heard the sound. I got an oil change and added seafoam to the tank and oil and tada the noise is gone. My mechanic said it could of been a sticky lift or something.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
