Muffler removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 01-21-2011, 12:29 AM Thread Starter
Muffler removal
I was going to attempt to remove my rear wheel earlier today, but I could not get my left muffler off. It is stuck on there pretty tight. I was able to get the clamp off as well as the heat shield. I sprayed some WD-40 on there and let it set, but still nothing.
I don't want to destroy the muffler until I get a set of slip ons, does anyone have any ideas?
Can the shift shaft seal be replaced without having to remove the engine?
I noticed a pretty good leak coming from it tonight. And I also noticed a lot of play in the shaft. Not up and down, but in and out, about a 1/4 inch.
I will look at the exploded parts list, but is that too much play?
It shifts great, and has never acted like it was stuck.
Thanks all.
RakerBill is offline
post #2 of 3 (permalink) Old 01-21-2011, 12:50 AM
Undo the shocks. This allows the wheel to move up and down. This will give the clearence you need to remove the axle.
post #3 of 3 (permalink) Old 01-21-2011, 03:49 PM
I don`t know about changing the shift shaft seal, but you can take up the 1/4" play with a few washers between the case and the shift lever.
