Oil leaking from exhaust??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-30-2006, 05:36 PM Thread Starter
hgree's Avatar
I pulled up in traffic on pretty steep grade to a red light in a town that I was unfamiliar with and the lady behind me pulled up exceptionally close to me and left no room at all for a slight rollback to engage clutch prior to take off. I let clutch slip just a little to create forward movement on the up grade and pulled out on to the main street. Within a block the motor started cutting out and I pulled over and the motor wouldn't run. Upon inspection oil was leaking out of the rear exhaust manifold. Pulled the rear plug and it was fouled. Front plug was clean. Cleaned and replaced plugs and motor started with some spitting and sputtering but finally picked up enough that I limped it home. Got home and put in new plugs checked oil and everything looked fine. Scooter started and ran fine, I rode 50 miles to and from work and no problems.
Any thoughts on where the oil came from???
Out of VN750s...
On to bigger and better things!
1997 Black & Silver ***SOLD***
Insurance Replaced: 08/25/2008
Mileage: 10/29/08- 4644 miles
Son's **Sold: In the ARMY & married $$$**
1995 Teal Green
Purch 08/17/2007: 14,240 miles
10/29/2008: 17,640 miles
Wife's **Sold: shoulder injury**
1999 Gray/Black w/Fairing
Purch 06/22/08: 18,160 miles
10/29/2008: 19,889 miles
hgree is offline
post #2 of 12 (permalink) Old 05-30-2006, 07:43 PM
Thats a tough one, had a similar prob with a Kaw V-twin(lawn tractor) The shop mechanic said I had overfilled the oil and it was getting pushed out of every orafice in the motor, I had 20 hours on that oil change so I don't know if in fact that was the problem. They drained and refilled the crankcase and changed the air filter as it had oil in it to. It ran fine after that but I still don't buy their diagnosis but anything is possible though I doubt you had to much oil in yours.
Woody is offline
post #3 of 12 (permalink) Old 05-31-2006, 09:51 AM
Make sure your airbox drain tube isn't clogged or crushed. The crankcase oil vapors are vented into it and can condense. There is a small tube at the front that runs down along the radiator to drain it.
wwmkwood is offline
post #4 of 12 (permalink) Old 05-31-2006, 01:15 PM Thread Starter
hgree's Avatar
Had 2400 miles on oil change and level was good; small bubble in sight glass on center stand w/ engine off and nothing in sight glass w/ engine running...
The grade of the street was steep enough to cause any oil to back of crankcase tho..
No oil up front and front cylinder was clean just the rear cylinder.
Out of VN750s...
1995 Teal Green
hgree is offline
post #5 of 12 (permalink) Old 06-02-2006, 08:11 PM Thread Starter
hgree's Avatar
New development!!!....
I went out and tried to start the motorcycle today and it backfired gas from rear exhaust and wouldn't start. Then raw gasoline poured out of exhaust pipe condensation hole in bottom of muffler. I closed tank petcock valve and will have to find someone to help fix????????? Evidently backfiring and oil in cylinder has messed up carb(s)? I checked the oil in crankcase and it doesn't smell like gas but I will still change it after carb repair.
Anything else I need to look at?
Out of VN750s...
1995 Teal Green
hgree is offline
post #6 of 12 (permalink) Old 06-02-2006, 08:57 PM
are you getting spark in the rear cylinder?
thet would be the first thing i check when raw gas is present?
free wheel-e is offline
post #7 of 12 (permalink) Old 06-02-2006, 11:13 PM
If you're not going to get it looked at right away I would pull the plugs and crank it to get all the fuel out the cylinder and spray with fogging oil just for good measure.
Woody is offline
post #8 of 12 (permalink) Old 06-03-2006, 08:51 AM
Loran in Npvl IL's Avatar
If you are getting that much gas, then the carbs are to blame. some crud could have made it into your gasline (from when it was in a steep incline) and now the float valves are not closing properly.
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #9 of 12 (permalink) Old 06-03-2006, 08:52 AM
I have not worked on the Kaw carbs yet but I would check the float level. It sounds like the rear float stuck open or the float level is to high and fuel spilled into the cylinder. This coulspossibly cause the problems you describe by "washing down" the cylinders and going past the rings to dilute the oil.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #10 of 12 (permalink) Old 06-05-2006, 08:56 AM Thread Starter
hgree's Avatar
Thanks for all the input!! I pulled the carbs and am overhauling them. I didn't find anything major pulling them off other than the keeper on the throttle slide had come loose on the rear cylinder carb. They were clean and no junk. No parts locally, had to be ordered naturally. Excess gas did make its way into oil and am changing oil prior to restart. While bike is down waiting for parts I am going to do stator fuse rewire and relocate regulator/rectifier.
Thanks again for the comments...
Out of VN750s...
1995 Teal Green
hgree is offline
