Vance & Hines Confusion - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-03-2006, 02:35 PM Thread Starter
Hello Group,
I am confused! I saw a picture somewhere of a set of V&H exhaust pipes on a VN750 and they looked great. There was one pipe on each side, like stock, the tips were round, not slash cut, like stock, and unlike stock, they were of equal length from the rear. By equal length, I mean from a top-down view, the tips of the exhaust are even with each other, on the stock bikes, the tips are not even with each other. Anyways, this is the exhaust I would like, however, I cannot find that exhaust anywhere. I donít know if it was a custom job or what. The only V&H pipes I can find are Vance & Hines Cruzer #31363. The picture for these shows both pipes on the right hand side with slash cut tips. I DO NOT like that look at all, I am all about the symmetry.
I know many of you guys have V&H exhaust so could you please tell me if there is something I am missing here? Do you have the pipes I described above? If so, do you know the part number? Thanks for the help.
Adam
bcjoker04 is offline
post #2 of 8 (permalink) Old 05-03-2006, 08:41 PM
I have the VH Cruzers you're talking about (one pipe on each side of bike) - I checked the website they were ordered from and it says the part# is 31363 and I also still have the box - so I ran out to the garage and double checked and it says #31363 too.
- The picture on the website I ordered them from shows them on the same side too, but I think that is a Vulcan 800 in the pic - here's the link
http://www.classiccruiser.com/srvs/c...ase=obj(144157)
hope it helps
PS - the pipes are awesome!
1999 VN750 Ebony/Pearl Chateau Grey
Master Cylinder cover (Kaw Fire and Ice)
Billet Mirrors
Plain Headlight Visor
Plain Tank Bib
Vance & Hines Cruzers
NEPA
cav_vet is offline
post #3 of 8 (permalink) Old 05-04-2006, 12:02 AM Thread Starter
Hey thanks Cav Vet, that was super helpful and very nice of you to check on that model number for me. I was searching all over the web for a different model but I guess they just put the wrong picture up. I really appreciate your help.
Adam
post #4 of 8 (permalink) Old 05-04-2006, 04:35 AM
Uber Member
just curious....do the V&H have a cross over pipe in the place of the goats belly?
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 8 (permalink) Old 05-04-2006, 10:00 AM
Search Goddess
Dianna's Avatar
No, In fact any after-market exhaust system removes the goats belly.
V&H replaces the entire system from the headers on. Cobras use the existing right header pipe (Something to consider if that pipe is discolored or banged up)
Also V&H comes with a built in heat shield so you will never see bluing on the pipes. Cobras tend to blue up fairly fast.
Because of the replacement the mufflers DO end up the same at the back of the bike giving a more balanced look rather than the "staggered" mufflers (which use to drive me nuts! I like a balanced look to my ride!)
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 8 (permalink) Old 05-04-2006, 10:01 AM
Loran in Npvl IL's Avatar
No cross over pipe or goats belly with V&H
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #7 of 8 (permalink) Old 05-11-2006, 05:51 PM
If I replace the stock exhaust whit the v&h will I have to reject???
mavericksdad is offline
post #8 of 8 (permalink) Old 05-11-2006, 07:32 PM
Search Goddess
Dianna's Avatar
You'll "reject" your goats belly (pre-exhaust chamber) but you won't have to re-jet. You only need to re-jet when you change the air intake such as doing an ear-shave (replacing the air filter "ears' with pods at the carb)
Sorry, couldn't resist!
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
