VN750 Starting issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-23-2006, 07:56 AM Thread Starter
i have a 87 VN750 and having starting issues
i have but a new battery in every year (just cheap ones)\
only happends when cold(or not cold just when sitting like 8h +)
push starting does not work either
there is new plugs on(Reg NGK)
tank uses Supreme gas
did this morning at 6:30am 4 degrees celcius
after i kill the battery trying to start you push start in 2nd and 3 gear
same issue nonthin
then i hook to car battery and voom starts first shot
any ideas
Thanks
rcmpayne is offline
post #2 of 12 (permalink) Old 04-23-2006, 09:23 AM
Search Goddess
Dianna's Avatar
Yes, \
Those cheaper batteries are great for lawn mowers, but our bikes take a bit more to start. Get a Maintenance free westco or yuasa battery. You will be pleased with the extra CCA and won't have to keep taking the seat off to check battery levels or worry about acid spills.
Also our bikes run just fine on regular gas. (87 octane US equivalant)
And thirdly, How are you trying to start the bike.
When cold the best procedure is 3/4 to full choke, NO throttle and hit the start button. Warm starts are no choke and just a blip of the throttle.
Also, are you getting anything at all when trying to start or just clicks or does it try to turn over but not catch?
Are you starting in gear or in neutral? If you are trying to start in gear you could have a sticky clutch lever or kickstand switch.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 12 (permalink) Old 04-23-2006, 09:34 AM Thread Starter
it just rolls over and over and over, in nutural it some times catches but if i hit the gas it kills
my choke is not working also
rcmpayne is offline
post #4 of 12 (permalink) Old 04-23-2006, 10:08 AM
Search Goddess
Dianna's Avatar
Sorry, but you need the choke for cold starts. Get that working and the cold starts will work.
What is wrong with your choke? Cable? Adjustment?
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 12 (permalink) Old 04-23-2006, 10:24 AM Thread Starter
the metel clip is not holding the cable at the carbs so when i move teh choke it moves the cable and the cable housing
i did not think there was a diff between opwning the choke and opeaning throttle half
lol
rcmpayne is offline
post #6 of 12 (permalink) Old 04-23-2006, 01:24 PM
Uber Member
yep there is a big difference.... fix that and do what dianna suggested, you'll see a huge difference in ease to start...4 deg cel that is what like 38 deg far..... you may also later find a way to block a portion of your radiator. i am in texas and under 45 deg far i find i need to block a portion of it. i will be making something before winter comes back around (thinking leather or pleather with velcro straps)
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #7 of 12 (permalink) Old 04-24-2006, 01:20 AM
Very good tips/hints and sugestions. My '91 was a hard starter and very cold natured, EVERYTHING was checked tweeked and tuned, but the problem just got worse and was compounded by poor idle, pops and backfires, after doublechecking I noticed my carb rubbers (dont know the correct word) had loose clamps, long phillips screwdriver and problem solved.
Rick_in_WA is offline
post #8 of 12 (permalink) Old 05-08-2006, 09:30 AM
Trouble starting when hot
My bike is hard to start when the engine is still hot. This is especially a problem at the gas station. You stop, fill up, and it won't start. Well, it will eventually, but it takes a few tries. I have thought it was a fuel delivery problem, like flooding or something. But reading posts either here on the yahoo group, I came across something about the rectifier getting too hot under the battery, causing weak fire. Has anyone here had this specific problem? I have already gone to a Yausa sealed battery. I have a '93 VN 750 with just under 18,000 miles. I have read up on the rectifier relocation, but since I don't have any extra electronics on the bike, I didn't think I would need to do this mod.
Russ
RLKelly is offline
post #9 of 12 (permalink) Old 05-08-2006, 09:34 AM
Search Goddess
Dianna's Avatar
See the pick-up coil adjustment I just posted https://www.vn750.com/forum/showthread.php?t=1580
This has solved a lot of hot starting problems
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #10 of 12 (permalink) Old 05-09-2006, 01:35 PM
fergy's Avatar
I'm building a bracket to relocate the r/r even with no electrical additions to the bike, but as part of my preventive maintenance. Just bought the bike three weeks ago. No problems starting, but when it's hot, it takes a couple trys, sometimes. I'll also be adding inline fuses to all three of the stator wires.
The problems with the r/r are mostly from heat from the location above the pre muffler, but adding any additional electrical components can excellerate the life of the r/r and if the r/r goes, you've more than likely lost your stator $$$. It's best to relocate the r/r to a cooler location no matter what your electrical load might be. The gel cell MF battery is also a must do! You'll spend less in the long run.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
