Jardine pipes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-27-2006, 10:34 AM Thread Starter
2FAS4U
Jardine pipes
I got a good deal on a set of Jardine pipes for my 05. They should arrive this week. Any suprises I should be aware of with the install? Thanks, 2FAS
2fas4u is offline
post #2 of 6 (permalink) Old 03-28-2006, 01:28 AM
Uber Member
how much u pay and where.... i've been looking at the jardines for some time now. i wonder how hard it would be to put a crossover pipe in there
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 6 (permalink) Old 03-28-2006, 05:45 AM Thread Starter
2FAS4U
I lucked out on E-bay and picked a set up. I'm actually a pretty good wrench. I am just curious if there are any fitment problems to look out for.
2fas4u is offline
post #4 of 6 (permalink) Old 03-28-2006, 06:12 PM
Uber Member
not that i have heard of....just make sure you use new gaskets.... there is a harley equivalent
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #5 of 6 (permalink) Old 03-30-2006, 10:20 AM Thread Starter
2FAS4U
I'll try and take lots of pics. Thanks, 2FAS
2fas4u is offline
post #6 of 6 (permalink) Old 04-10-2006, 04:10 PM Thread Starter
2FAS4U
Put the pipes on this weekend. Sound great without alot of noise at cruise speed. The directions tell you to cut 5 inches off the right side pipe for the mufflers to bolt together at the rear. I chose instead to use a bracket to attach the mufflers together, in case I ever needed to put the stock ones back on. My bike is an 05, so removal took about 20 minutes, and the install was almost as quick. I'll try to get some pics up.
2fas4u is offline
