Advice on removing stock exhaust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-01-2006, 11:24 AM Thread Starter
DMAG's Avatar
Hey all,
I'm getting ready to remove the stock exhaust on my 1985 VN700 and put on my new V&H Cruizers.
Now mind you, these pipes have been on the bike for over 20 years! So to aviod any "problems" like breaking a stud, etc...I want to make sure (being the anal person I am) that I am prepared as possible.
My brother said to squirt it with a good rust penetrant the night before and then run the engine for 15 minutes prior to loosening the bolts (to expand the metal).
Any other tips, tricks or advice to make removing the exhaust as painless as possible?
T'anks!
Anthony
1985 VN700 (Priscilla) Sold
Helpful Links -->>
Search | Vulcan Verses | VN750 Gallery | VN750 Items on Ebay | Link to VN750.com
DMAG is offline
post #2 of 5 (permalink) Old 03-01-2006, 12:46 PM
Originally Posted by DMAG
Hey all,
T'anks!
Your brother is a smart man.
Be patient after spraying the penetrant and allow it time to work. Go have some coffee or a snack while it does it's work.
Not sure if you already have the lubricant but SeaFoam makes a good product for that purpose. It's called Deep Creep. You can buy it at Napa Auto Parts Stores.
When a penetrant and lubricant are needed – for a multitude of uses.
Your service technician uses SEA FOAM DEEP CREEP to penetrate and lubricate many critical areas and items. SEA FOAM DEEP CREEP is even used upside down to get at difficult areas that need treating. DEEP CREEP is used in many of the technician’s services.
When a carbon cleaner is needed – to spray into carburetors of all types, throttle body throats, pcv valve or main manifold vacuum lines.
Your service technician can offer a SEA FOAM DEEP CREEP treatment as part of a pre-tune-up cleaning.
When air intakes need cleaning – causing rough idles or stalls, because throttle plates are dirty.
Your service technician can offer a SEA FOAM DEEP CREEP treatment to safely clean the throttle plates and system.
When engine fogging is required – to store engines for long periods of time without running them.
Your service technician can offer a SEA FOAM DEEP CREEP treatment to thoroughly saturate an engine internally to lubricate it and protect it from gum, varnish and moisture problems. He can perform this service or show you how to do it yourself with SEA FOAM DEEP CREEP.
When air tools need to be lubricated, cleaned and moisture removed – this should be done on a daily basis.
Your service technician can offer a SEA FOAM DEEP CREEP treatment to lubricate and remove the moisture from air tools on a daily basis. This treatment insures the longevity of the tools. He can service your air tools or show you how to do it yourself with SEA FOAM DEEP CREEP.
When a moisture disperser is needed – to disperse moisture.
Your service technician can use SEA FOAM DEEP CREEP to disperse moisture off metal parts and surfaces. It is used on wet engine parts, bolts, clamps, etc. to lubricate and keep from rusting. This service is performed when needed.
When a door lock lube & de-icer is needed – to lube & de-ice locks.
Your service technician can offer a treatment of SEA FOAM DEEP CREEP to spray into frozen or corroded locks to dry, melt ice and lubricate or show you how to do it yourself with SEA FOAM DEEP CREEP.
When a starting spray with lube is needed – for hard starting engines of all types. For best starting results, deep creep must be kept at room temperature to be effective in cold weather.
Your service technician offers a SEA FOAM DEEP CREEP starting service or can instruct you on a do it yourself process using SEA FOAM DEEP CREEP.
When a gun cleaner and oil is needed – this is one example of the many uses of SEA FOAM DEEP CREEP for do-it-yourselfers.
DEEP CREEP cleans, dries moisture, dissolves buildup of gun powder and lubricates parts with only one application.
whistle clean is offline
post #3 of 5 (permalink) Old 03-16-2006, 11:18 PM
Sounds like this product will be able to replace duct tape.
brianjenwaldner is offline
post #4 of 5 (permalink) Old 03-17-2006, 08:14 AM Thread Starter
DMAG's Avatar
...as long as it doesn't replace bailing wire!
Actually I'm a Seafoam junkie myself.
Anthony
Helpful Links -->>
DMAG is offline
post #5 of 5 (permalink) Old 03-17-2006, 10:31 AM
LOL...I'm afraid I'm a duct tape junkie so I might not be able to let it go.
