De-Baffled - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 34 (permalink) Old 09-22-2009, 09:33 PM Thread Starter
STUMPYSKAW's Avatar
De-Baffled
I've got some pics in my album of how I De-baffled my stock pipes. Sounds great.
I took her for a ride today not expecting any power difference, since I still have stock jetting and was already running a tat lean in the mid to upper. I was surprized, she has more pull throughout the whole range. Still alittle lean at WOT, but better than before. Still not the perfect sound, but alot better than stock.
"DAISY" 85 VN 700 19K
Owned since 09/12/09
Done list
Metal radiator drain plug
Removed exhaust baffles
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
VN900 seat on my VN700
https://www.vn750.com/forum/showthread.php?t=12903
Debaffling my stock pipes
https://www.vn750.com/forum/showthread.php?t=12756
STUMPYSKAW is offline
post #2 of 34 (permalink) Old 09-27-2009, 12:53 AM
bbowles's Avatar
Hey Stumpy,
I just got my 05 this morning... how'd you get the baffles out? Does yours have an air induction in the exhaust? Does it back fire alot with no back pressure? and finally, Will the muffler slip apart at the seam there in the middle?
Just a question or two!!
Any advice can help!
Thanks
bbowles is offline
post #3 of 34 (permalink) Old 09-27-2009, 01:16 AM Thread Starter
STUMPYSKAW's Avatar
Cangrats on getting the bike, As long as you grind out around where the hole-saw cut is,the baffles should slide out with a little twisting. Make sure that the spot-welds on top &bottom are ground flush too(on the inside of the pipe). I used a pair of pliers to grab & pull them out. I'm assumming you looked at my album pics. As for the Exhaust I've "marbled" my bike. for more info on marbleing take a look in the versis part of this forum. It has alot of info on Marbleing and coastering the fresh air induction. My bike only pops every once in a while, usually on a hard decel,and it's usually only one pop. I also turned my fuel mix screws on the carbs 3 turns out from bottoming. Haller if you need any help. thers a lot of nice knowlegable poeple on this site waiting to help.
Tools I used
Drill slow so you Don't burn up the bit.
Grind The cut smooth and make sure the spot welds are flush with the inside also.
Use a pair of pliers to pull the baffles out. youmay have to grind more if they don't want to come out with a little twisting.
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
post #4 of 34 (permalink) Old 09-28-2009, 12:40 PM
dirtrack650's Avatar
Hope they never do DMV sound checks in your state. Washington State is checking now. Had a few guys get pulled over and ticketed on the spot.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 34 (permalink) Old 09-28-2009, 03:52 PM Thread Starter
STUMPYSKAW's Avatar
I don't think they do. Most V-twins around here are runnin un-baffled exhuast, so if there is a law than MO doesn't enforce it.
I had to fix my shifter today ( Bike was stuck in neutral), and as an update to this thread I just got done removeing the rest of the exhuast and useing a long chisle and hammer gutted the rest of the baffles in the mufflers. I also used the same tools to punch through the goats belly to make it strait through. What a difference in sound and a little on the performance. She's real tourqie now and still pulls hard up top. This part of the exaust was a real pain to do, but worth it to me.
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
post #6 of 34 (permalink) Old 09-28-2009, 10:58 PM
Vintage bike addict
antiq's Avatar
Will someone please explain to me why louder is better? Do you really enjoy the ringing in your ears? Or do you feel compelled to do battle with the kids and their fart can mufflers?
Eleanor Roosevelt.
antiq is offline
post #7 of 34 (permalink) Old 09-28-2009, 11:04 PM
G3P0's Avatar
Imho, louder is better because people notice you.. I have no base for comparison on drilled baffles, I've heard stock and V&H Cruisers and I must say, I love the sound of the Cruisers, and they are LOUD, but it's the sound I like not the volume, well I do, but like I said, people notice you, and thats a good thing when they usually don't - safety measure? performance boost? sound....
85 VN700 Project Bike
Earshave
Mustang Seat
Custom grill cover
Busted Engine... removed, split, waiting on parts
Cleaning up & painting the rest
Parts still needed... wanted...
11" shocks, or one stock
Aftermarket exhaust... eventually
Extended forward controls or custom hwy peg mounts for my cramped legs...
G3P0 is offline
post #8 of 34 (permalink) Old 09-28-2009, 11:16 PM Thread Starter
STUMPYSKAW's Avatar
I didn't do it all for the noise, mostly for performance. I hope your not comparing my bike to some "fart can" car that has a higher DB rating than it has horsepower. I noticed a big diff in power, but yes it is a little louder. I hope I'm not coming across as being irritated, becuase everybody has an opinion. I just wanted to let you now mine. I've had a life-long addiction to horsepower. The feel, sound, and the smell of it is my drug.
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
post #9 of 34 (permalink) Old 09-29-2009, 12:35 PM
Vintage bike addict
antiq's Avatar
If the performance actually has improved ok. Without richening the carbs I'm guessing your valves will suffer some burning. As far as the safety aspect goes. The sound follows you it doesn't precede you as much as you might think. The guy in the cage behind you hears it much louder than you. Do you feel safer irritating the squishmobile behind you?
I have no wish to offend anyone here or in traffic. Around here no one really sees motorcycles in traffic except other bikers. People can't even be bothered to use their signals because they are busy yakkin on their cell phones.
Regardless how much sound you produce. Ride safe out there.
Eleanor Roosevelt.
antiq is offline
post #10 of 34 (permalink) Old 09-29-2009, 12:43 PM
I'm running a completely drilled goat with HD Sporster XL mufflers ($10 eBay) and love the sound. It's not loud, but has a nice mellow tone to it when holding a steady throttle. Get on it a bit and it sounds nice. Drag pipes tend to be really harsh with that edgy gritty sound and wtih our high RPM twins, that's not for me.
A 2 into 1 with stainless glass pack muffler would be my choice but that's a custom job costing more than I can pay.
Something like this...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
