Issues after drilling baffles - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 19 (permalink) Old 05-04-2009, 07:23 AM
VulcanCruizer's Avatar
Originally Posted by OlHossCanada View Post
There`s a link to a website that I can`t find right now, where the guy has a couple of pieces of 3" chromed truck exhaust tips a foot long or so. They were welded onto stock mufflers, I think, and were supposed to have a deeper rumble sound. I would like something with a deeper rumble w/o being louder.
I thinik this is the site you're talking about. Looks pretty cool.
http://www.fortunecity.com/bennyhills/radner/499/
1989 VN750
Purchased 4/26/2008 @ 27,320 Mi
Upgrades:
Travelcade Mustang Seat
SpitFire Tinted Quick Release Windshield
Degoat, Drilled & Jetted
Leather Saddle Bags
Johar Signature Grips
Deka ETX15L Powersports AGM Battery
NGK DPR7EIX-9
Upcoming:
1991 VN750 Project Bike
Purchased 4/30/2011 @ 31,970 Mi
VulcanCruizer is offline
post #12 of 19 (permalink) Old 05-04-2009, 01:04 PM
That is the one I was looking for. I thought there was a link at the LINKS function at the top of the page, but could not find it last night. I also like that they are the same length and not staggered.
post #13 of 19 (permalink) Old 05-04-2009, 01:15 PM Thread Starter
Jace Bror's Avatar
I havent taken our mufflers off to know, and I usually ride with bags on. But are the mufflers on our bike actually two different lengths or is it the way they connect to the goat?
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #14 of 19 (permalink) Old 05-04-2009, 02:29 PM
At Least I Can Spell!
msh1156's Avatar
speaking of adding on additional pipes.... would this work for the 750?
http://www.gadgetjq.com/valk_tips.htm
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #15 of 19 (permalink) Old 05-04-2009, 02:41 PM
fergy's Avatar
If you look at a goats belly, you'll see that the exit flanges on both sides facing the rear of the bike are at different locations, one further back than the other. That's why the mufflers are staggered.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #16 of 19 (permalink) Old 05-04-2009, 04:16 PM
. Also I have been thinking of getting the bar end weights that Kuri makes. That should help there, I hope. But my rear still needs help.
I hate these kinda things.
This is the first time that I have heard of bar end weights.
Is that what those cone shaped pieces are on the end of some Kury grips? I thought they were just chrome bling.
Do I understand correctly that they dampen vibration in the handle bars as well?
post #17 of 19 (permalink) Old 05-04-2009, 04:29 PM
Hmmm, does anyone have a Nomad to compare diameters of that muffler with a VN`s?
post #18 of 19 (permalink) Old 05-04-2009, 09:23 PM Thread Starter
Jace Bror's Avatar
Nope not referring to the cones. I saw recently they have bar end weights. I don't know what they weigh, I just know the heavier they are the better they are supposed to be with helping reduce vibrations. seen guys use them on sport bikes.
post #19 of 19 (permalink) Old 12-24-2019, 11:50 AM
Paulanan's Avatar
In general, vibration diminishing of streamlined heat-transmitting elements is achieved by (e.g., decreasing the flow velocity) clearing of faults in damaged tubes, rearrangement of tubes to make passages for a coolant, replacement of damaged tubes by bars, mounting of regulating baffles at the coolant inlet in the heat exchanger, and appliances reducing damping and tube stiffness. Bearing in mind that the strongest vibrations are observed in the first rows of tube assemblies, tube clips in midspan, stiffness-girdling rings, and other appliances reducing vibration amplitude can be mounted.
Paulanan is offline
