Extra Parts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-22-2020, 07:04 PM Thread Starter
Jason Pittenger's Avatar
My engine is MOSTLY together, and I have extra parts!!!! Where do these go? HELP!
A washer and two bolts with a "4" on the head. I put them next to a spark plug for size comparison.
I took pictures during disassembly, but I don't see these parts. I never split the case, and my engine removal parts were kept on a different shelf.
My pictures of disassembly:
https://photos.app.goo.gl/MvU3U33ddipteaD46
ID:	47867   Click image for larger version
ID:	47871   Click image for larger version
Completed modifications:
Planned modifications:
Jason Pittenger is online now
post #2 of 9 (permalink) Old 05-22-2020, 07:12 PM
What size hex on them?
Did you have the battery box unbolted?
post #3 of 9 (permalink) Old 05-22-2020, 08:35 PM Thread Starter
I just remembered the bolts are from the rectifier relocation, and not needed. I am down to just the washer.
post #4 of 9 (permalink) Old 05-22-2020, 08:40 PM Thread Starter
The washer ID is 11mm, OD 20mm, about 1.5mm thick.
post #5 of 9 (permalink) Old 05-22-2020, 10:09 PM
Is there supposed to be washers under the acorn nuts on top of the heads?
What about the long engine mount bolts... Washers there?
post #6 of 9 (permalink) Old 05-23-2020, 08:01 AM Thread Starter
It looks like it is 92022-1591 on the cylinder head.
https://www.kawasakipartshouse.com/o.../cylinder-head
Under one of the large head nuts.
Given the that they are supposed to be torqued in a specific order, am I ok to just remove and retorque the one nut, or do I need to redo the whole head?
post #7 of 9 (permalink) Old 05-23-2020, 09:03 AM
I think you'd be fine with doing one. It won't unclamp the entire head.
I've done it myself and never a problem.
post #8 of 9 (permalink) Old 05-23-2020, 01:07 PM Thread Starter
Thank you so much! Using a right angle dental pick, I found the nut that was missing it's washer. Fortunately, it wasn't the nut underneath the camshaft, so I only had to re-seat the valve cover & gasket.
Thank you!
post #9 of 9 (permalink) Old 05-23-2020, 01:13 PM
You're welcome, looking forward to seeing it get fired up. Getting closer.
