Oil Pressure Sender Gasket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-18-2020, 09:05 AM Thread Starter
Jason Pittenger's Avatar
I am rebuilding my engine and I forgot to order the copper crush gaskets for the oil pressure sender. I found some at my local hardware store, but they are thinner. ID and OD match. Will these work?
I have them pictured next to the old ones.
ID:	47829   Click image for larger version
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #2 of 4 (permalink) Old 05-18-2020, 11:02 AM
You should be fine with that. I reused mine a few times before replacing the sending unit.
I don't think the crush is so important on that piece, as long as it has one on it, old or not.
post #3 of 4 (permalink) Old 05-18-2020, 11:29 AM
should be ok, just need the soft copper to crush a little to give a good conformance to both surfaces
michiganteddybear is offline
post #4 of 4 (permalink) Old 05-18-2020, 03:59 PM Thread Starter
This is what I was thinking, but I wanted to be sure.
