Oil leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 05-02-2020, 10:10 PM Thread Starter
Oil leak
I have oil leaking from stator wires I had it before sealed it up was fine for a while but now I’m noticing it leaking again but there is slight pressure coming out now why would there be pressure and oil coming out?
Christopher J Weresow is offline
post #2 of 2 (permalink) Old 05-02-2020, 10:58 PM
Originally Posted by Christopher J Weresow View Post
I have oil leaking from stator wires I had it before sealed it up was fine for a while but now Iím noticing it leaking again but there is slight pressure coming out now why would there be pressure and oil coming out?
Some level of crankcase pressure is normal. You get a free oil shower if you fire it up with oil cap removed. Stator wires are near the oil cap.
Might be able to slide the stator case out far enough to slide the grommet, and reseal?
If oil gushed out of the crankcase vent up front, that would mean a problem has occurred that raised crankcase pressure.
