Head Gasket Orientation? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 44 (permalink) Old 03-17-2020, 12:02 PM Thread Starter
I just tore into my engine and replaced the head gaskets which were worn out, which I concluded from the coolant dripping out the tailpipe. I just reassembled the engine, and when I drained the oil- it is still milky looking (was brand new oil). Is there a proper orientation for the head gaskets which could be preventing them from sealing properly, or is there more likely a leak elsewhere?
Thanks as always.
jakob_rothfuss is offline
post #2 of 44 (permalink) Old 03-17-2020, 05:38 PM
Not sure about orientation. Don't see anything in the manual, and haven't heard anything about "This Side Up" for the head gaskets.
Did this engine run 1-5 minutes before the oil change? On this engine, air entrainment in the oil during warmup makes the oil look murky, milky looking until it's completely hot. It can take quite a while to get this engine to normal temp just by idling. 10-15 minutes in cool weather.
Hopefully that's all it is. You could let it run until completely warm, then have a look. Short ride is even better. If in doubt, you could drain the oil into a clear container and let it settle overnight.
Water pump seal is another spot to get coolant in the oil.
If you didn't drain oil from the filter screen on the side, there's some extra oil in there. Not sure if it would be enough to show up milky, but maybe.
post #3 of 44 (permalink) Old 03-17-2020, 08:45 PM Thread Starter
Thanks for the reply- right now I'm changing my oil again, since there was previously a great deal of coolant contamination in the oil. I'm hoping there was just a lot of residual left in the engine. I got it up to normal temp tonight after doing so, and noticed what you meant about the air.
Where's the oil filter screen located? Should I check that and clean it out?
post #4 of 44 (permalink) Old 03-17-2020, 09:24 PM
The oil screen is on the bottom left side of the engine, the cap has a 17mm hex facing straight out to the left side. There's an o-ring on the cap, a spring, then the screen, there's a split rubber gasket on the screen.
Definitely drain this every oil change, there's more oil in there, maybe 10oz. In this case, milky oil. Inspect the screen for debris, small bits of clutch material is normal, but larger rubber debris usually means failing damper bushings.
Here's a link for the repair manual in case you need it: VN750_Vulcan_Service_Manual_Parts_Catalogue
post #5 of 44 (permalink) Old 03-17-2020, 09:38 PM Thread Starter
Thanks for the link and info!
post #6 of 44 (permalink) Old 03-18-2020, 10:09 AM
You're welcome, let us know how it goes.
post #7 of 44 (permalink) Old 03-18-2020, 02:06 PM Thread Starter
All seems to be normal now. Guess the filter/oil change was all it needed. Now I just have to figure out why the motor shifts into gear but the rear wheel doesn't move. Clutch problem? Just rebuilt the driveshaft so I know all is good there.
post #8 of 44 (permalink) Old 03-18-2020, 05:04 PM
Couldn't rule out the clutch yet, but I think it would have to be completely toast, unless somehow it's stuck in the released position. Clutch cable has free-play and the alignment was done when re-installing everything? Any trouble when installing the clutch arm, etc?
How about the shifter, does it still feel like it has spring action. Or, does the neutral light work? Does it go off when you plunk it into first?
First candidate is splines on the driveshaft or final drive, but ...
post #9 of 44 (permalink) Old 03-18-2020, 05:08 PM Thread Starter
Yes- all of the above about the clutch are true. There is play in the handle, and it shifts into gear fine. Neutral light is on when in neutral, and off when placed into gear.
I just performed a spline lube on the driveshaft. That doesn't mean I didn't put it back together wrong though. Haha- i'll take a dig into that next.
I'm getting some white smoke out the front cylinder exhaust pipe again- thinking I might have a bad seal by water pump since both head gaskets are indeed new. Only in front cylinder, not rear cylinder (white out the right tailpipe). It does seem that once the engine warms up that this smoke stops so could to be a lot of condensation? I do not know how long he engine sat with the previous owner and I had it in pieces for a month or two.
Thanks a lot
post #10 of 44 (permalink) Old 03-18-2020, 05:17 PM
What was the reason for rebuilding the driveshaft? Did you inspect the splines on the shaft coupler? Was there a lot of red dust in the coupler, or just old grease?
Water pump won't put coolant into a cylinder, just the oil.
If it still has stock pipes, the exhaust mixes in the "goat's belly", so front/rear exhaust is all the same. I would lean toward condensation, especially if there's temperature swings in your area.
